Code P1121 Coolant Flow Control Valve
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by seabright_sc, Jul 31, 2015.
  1. seabright_sc
    seabright_sc Junior Member
    Santa Cruz
    Thought I would post this to help others who may have similar situation.
    2005 Prius, 130K, Check Engine Light came on. Code: P1121 Problem: Coolant Control Valve may not be operating correctly.
    Per CA Emissions Warranty, repair was completed by dealership free of charge. I called Toyota directly at first, they said it was not covered by warranty. Then I checked with local dealer who ran the vin and said it was covered and fixed it that day. Stoked for great local dealership service.
    m.wynn likes this.
    51,155
    cool! i wonder how coolant falls under emissions? well done, thanks!
  3. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    The 3-way valve controls flow to the thermos, Bisco.
    Prius P1121: Coolant Flow Control Valve Position Sensor Stuck - Luscious Garage | Hybrid Specialists
    Great news and great dealer for sure. I've heard of the 3-way valve being done under warranty before but can't remember if it was also in Cali. Sure seems like one of those areas where the "typical" dealer may not feel it's a warranty item.
    Coincidentally, I did the 3-way valve in my daughters '07 a week ago tonight. I pulled the 3 inverter mount bolts and swapped the valve topside as the Luscious blog states with little fanfare. At 152k miles, it was due for it's second ice coolant change so I drained it all from the rad and the thermos. Yeah, the re-fill and the bleed of that circuit are every bit the pain in the nice person that anyone who has ever done it says it is. Used Pat Wong's relay jump trick and several drive cycles to get it fully topped and gurgle free. I think edthefox5's method of dumping and refilling the rad at set intervals sounds better than doing a full circuit drain again!
    #3 m.wynn, Jul 31, 2015
    PriFi and bisco like this.
    51,155
    thanks!(y)
  5. Priusblood
    Priusblood New Member
    Silver Spring, MD
    Just did this last night on an 07. No coolant came out of the hot coolant tank cock but a lot came out when I took off the lower hose. BTW where are the 3 mounting bolts for the inverter?
    Shout out to Patrick Wong as well!
  6. JTM2955
    JTM2955 Active Member
    475
    185
    Mine has made funny noises for years. No codes yet.
    LG G3 T-MOBILE phone ☎
  7. bobodaclown
    bobodaclown Member
    216
    72
    My 09 with 98k is in the shop with p1121 Extended warranty is covering it and the rear hatch release. Should cost $50 out of pocket.
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
  9. bobodaclown
    bobodaclown Member
    216
    72
    Got it fixed along with the rear hatch latch release. $50 deductible. Life is better.
    Nexus 7 ?
