Code scanner recommendations?
Discussion in 'Gen 2 Prius Technical Discussion' started by fap, Mar 23, 2017.
  1. fap
    fap New Member
    va
    Hi Prius owners....
    Can anyone recommend a good code scanner for a 2005 Prius?
    I know they're all probably the same, but I figured it was worth asking.
    A mechanic friend recommended the Actron Elite CP9185.
    Curious to hear your thoughts.
    Happy driving.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Most on here use the Mini-VCI cable found online, costing around $18-$30. This cable allows you to use the Toyota Techstream software, which may offer better/different results over that all-in-one hand held scanner.
    ** Note this cable requires a windows type computer to run the software.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    You might consider getting a ScanGauge-II, although they're not cheap. I bought my 2nd (they can be daisy-chained) on eBay, and the manufacturer (Linear Logic) gave me a free upgrade for the firmware for the second! (Thankyou LL!) I paid ~$150 for the first (from Ye Olde PriusChatte Shoppe) and <$100 from eBay! Good luck! And welcome to PriusChat!
    PS as well as scanning the codes, each SG-2 allows you to set up four (4) useful X-Gauges, I have mine set up for RPM(ICE), °F(ICE), V(AuxBattery), HP(ICE), %SoC(TractionBattery), V(TractionBattery), ±Current(TractionBattery), %(Fuel) - hope this helps - Wil
    #3 WilDavis, Mar 23, 2017
  4. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    If you are going to carry it around in the vehicle then Scangauge, if you want just a code reader, you can't do better than a mini VCI setup (same as dealer uses).
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Techstream is freeware, see techstream inconsistencies | Page 2 | PriusChat
    You DO NOT want the most current version, really anything later than the vehicle build date will be good. I have 10.10.018 and still looking for a compatible cable. My PUMA *should* work, but I cannot find the OBDII adapter for it :(
  6. Phildo
    Phildo Active Member
    138
    108
    Perth, Western Australia
    i-Tech
    Is there any particular version which could be considered the best and the one to get?
  7. dolj
    dolj Senior Member
    8,212
    4,183
    Wellington, New Zealand
    No, not really. Pretty much anything after V4.xx.xxx up to ver 10.xx.xxx. The only real advantage of getting the newer versions is being able to use it on newer cars (up to the new models added in V10). If you only intend to use it on your Gen II any version that supports Gen II is good enough.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    A simple Bluetooth OBDII device works fine when coupled with the Torque app download to an Android phone/tablet.
    Cost you under $20.
  9. Qvox
    Qvox New Member
    Georgia
    If I buy this cable, will the software load and be usable on a Windows 10 machine. I only have one windows laptop and it is running the newest version of windows. Everything I've read concerning the free download of Toyota's Techstream references windows XP or windows 7.
  10. dolj
    dolj Senior Member
    8,212
    4,183
    I have heard of it being done successfully, but I have also read more stories where they tried and failed.
    Personally, I would create a Win XP or Win 7 (32-bit) VM within Win 10 and install the cable and software there. Once installed, disable the network connection, just to be safe. Install v10.xx.xxx or less of Techstream.
  11. Qvox
    Qvox New Member
    Georgia
    Thank you for responding.
    There's one available on Amazon, it will deliver faster, are these the same units and software packages. The reviews on Amazon are mixed. LINK
  12. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    You can put it on Windows 10, but it takes more effort.
    I have yet to see a step by step that makes it so that a complete novice can install it with no hiccups along the way.
  13. dolj
    dolj Senior Member
    8,212
    4,183
    I think you will find mixed reviews on just about all of them, as the customer base will be a mix of technically illiterate to IT super heroes. You need to read between the lines.
    My opinion is that these Chinese knock off cables are all much of a muchness. I'd put more stock in the credibility of the seller that has good feedback for after sales support and who was local. Don't necessarily buy the cheapest either.
    Having said that, this is one of those 32-bit versions, so I'd not phaff around trying to install in Win 10 (The instructions are there in one of the reviews, if you want to give it a go, though). Just create a fresh Win 7 (32-bit) (or Win XP) VM. Then make a copy of it and then start your install in the copy. Why? It will be so much easier to start fresh when you get to the point you want to pull your hair out. You may not, if the install instructions are good, but better to be safe than sorry.
    PS, even if you elect to install in Win 10, create a VM so it is isolated from the rest of your system and so you can disable the network connection in the VM. You don't want to be faced with unwelcome easter eggs on your only Win system.
    bikr357 likes this.
