Codes C1241 and C1300 (ABS)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by PtPri, Aug 11, 2021.
  1. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    C1241 - Low or High Power Supply Voltage
    C1300 - Skid Control ECU Malfunction
    2016 Gen4.
    OBD codes downloaded via Carista diagnose.
    I have no apparent flaws, no warning lights, no messages...
    Should I be concerned?
  2. ChapmanF
    17,326
    Could that somehow be on a screen of history codes?
    If those are current codes, I'd also expect dash lights.
    PtPri likes this.
  3. Justin Lippert
    Justin Lippert New Member
    Charleston, SC
    same exact thing just happened to me… 2016 gen 4, plugged in Carista (finally disabled the reverse beep :D) and it threw those two codes…
    you ever get any more information?
  4. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Have the 12v Battery tested. If its on its way out funny things can happen with all of the modules and sensors cars have in them now.
  5. Kurama
    Kurama Junior Member
    Md
    i'm having a similar issue with my 2017 prime advanced. we bought ours used from carvana. had the battery tested, and the voltage is fine, although it's not the exact correct battery model.
