Codes P0A93 and P0A94 occured today
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Sinoman83, May 29, 2016.
  1. Sinoman83
    Sinoman83 Junior Member
    16
    San francisco CA
    2012 v five with 56,500 miles. Getting onto an onramp and accelerating when car jolted and dramatic power loss. I posted a thread about my car "ticking" as i slowed down from 30mph and im wondering if this was related. I had no choice but to drive it home and kept car under 45 mostly on side streets. Car is not assited at all by electric motor and can bearly go up hills. With windows open and attention to any unusual sound i noticed no more ticking when slowing down from 25 to zero.... I think its covered under warranty at least powertrain, hopefully. I know a few of you here have the ticking problem to so i will update if this is related after i bring it in for service.
    49,371
    all the best!(y)
  3. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    Did you have the inverter recall done?
  4. Sinoman83
    16
    San francisco CA
    Yes i believe i did.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Being in a CARB state your hybrid warranty is 10 years or 150k miles so take it to the dealer and let them diagnose.
  6. PriusInParadise
    180
    91
    Hawaii
    The reason the ticking while braking is now gone is that when those trouble codes set, regenerative braking is disabled (along with much of your hybrid drive). The ticking is often due to excessive clearance in the outer CV joint of the front drive axle on the side where you hear the noise. It becomes audible during regenerative braking when the braking force is going from the wheel to the transaxle. When regen is disabled, you have friction braking at the brake rotors, with no load on the CV joints.
    The drive axles should be covered by the 5year/60k powertrain warranty. Depending on the delivery date, you might still make it. Of course, the you need a dealer tech to verify that this noise is coming from the CV joint. Based on past postings here, that may not be an easy task.
  7. Air_Boss
    3,939
    1,076
    New Yawk
    "When regen is disabled, you have friction braking at the brake rotors, with no load on the CV joints."
    CV joints are definitely still loaded, just differently than when the braking is regenerative.
