coilovers
Discussion in 'Prius c Accessories and Modifications' started by Priusxrs, Jan 12, 2013.
  1. Priusxrs
    Priusxrs Junior Member
    61
    Pa
    Hey just wondering to the people out there that did drop there C with yaris coils did you have to mod them in anyway or did they just bolt right on? Im looking at a set of tein street basics that a friend wants to get rid of they were on his 2011 yaris 3door. If anyone has any feed back from those coilovers too that would be great too. Thanks ahead of time : )
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    two-door yaris is my dream hybrid, maybe by 2017....
  3. TrafficMPG
    TrafficMPG Junior Member
    Although the parts may fit, the weight distribution is different and will create an imbalance. Prius C is heavier in the back and will droop with regular Yaris springs. Here is a great thread that includes suspension changes: cAstro my Prius c: Project thread | PriusChat
  4. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    They 100% bolt-in; the suspension is identical between the Yaris and Prius C. The differences are in the damper and spring tuning. Since the Prius C is slightly lighter up front and heavier in back, the only way I recommend adapting Yaris suspension pieces is to be able to adjust the ride height so you can keep the chassis attitude similar to stock. FYI, the geometry of this car is best when the car is lowered about 1 inch. More than 1.5" lower than stock starts pushing the roll centers to undesirable locations and the induced understeer counteracts the improvement in CG.
    I wouldn't stress too much about the spring rate changes, as there's nothing you can do unless you go full-custom. Putting Yaris coilovers with their respective spring rates will induce some understeer and some slightly floaty bump compliance at low speeds, but the car will feel more stable at high speeds. You can counteract the understeer by adding a rear anti-roll bar. In the end, you can make it work quite well.
    PriusCamper and acere like this.
  5. Priusxrs
    61
    Pa
    Finally got my coils now just need a nice day off to put them on. Hes what she looks like pre drop
    SGH-T889 ? 2
    ztanos likes this.
  6. Ryephile
    418
    151
    24
    Metro Detroit
    Did you end up with those Tein's?
  7. Priusxrs
    61
    Pa
    No got megan racing street ones cause they have the damping i can adjust
    SGH-T889 ? 2
  8. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    How do you like them?
    In my experience, they ride very stiff due to the short stroke.
  9. Priusxrs
    61
    Pa
    Finally got them installed and so far Love them im not as low as I could go with them but I am low enough i some how broke the outer axle boot so now I have that issue lol never a dull moment.
  10. Priusxrs
    61
    Pa
    SGH-T889 ? 2
    RightOnTime, X3kenster and ztanos like this.
  11. B2FiNiTY
    979
    226
    That looks really good! and pretty low... tucking tire
  12. mahout
    mahout Active Member
    655
    116
    NC
    You sure about C being lighter in front than the Yaris ? Ours was 44 lb heavier; the aftermarket lowering springs had no effect on the weight distribution. Its still 61% front and 39% rear. Disconnecting the front antisway bar substantailly reduced the understeer, thank goodness. And so does wider wheels with less offset. (effectively widening track). Take a look at you tube's Prius Handling. Keepig up with S200 and Caddy in corners ain't haf bad.
  13. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Looks really good!!
  14. X3kenster
    X3kenster Junior Member
    28
    Drop looks great. Have you attempted to max out the ride height to see how low you can get? im in the market for coilovers and looking for one that can get me low as possible. Would like to know if Megans would be right for me.
  15. geero
    geero New Member
    How much do Megans coilovers run if you don't mind me asking
  16. Priusxrs
    61
    Pa
    Got mine from micro image think they were 860ish
    SGH-T889 ?
