Cold air from heater and P0117 code.
Discussion in 'Gen 3 Prius Main Forum' started by WeidnerL, Nov 20, 2019.
  1. WeidnerL
    WeidnerL Junior Member
    Suddenly no hot air out of heater and red hot engine indicator. First steady and showing on and off in first 5 or so miles. Code set is P0117 " "Engine Coolant Temperature (ECT) Sensor Circuit Low Output Problem".
    Could be several things, but what is your experience with this and how should I approach this? Thermostat? Water Pump? Most common reason?
  2. WeidnerL
    Oh yes...It is a 2010 Prius with about 200K miles.
    51,154
    there is also a 3 way diverter, subsides would probably nail it down
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,036
    519
    Tucson, AZ
    2021 Prius
    Don't thermostats usually fail open? You notice it when the engine is running cold. Not sure how you check for ICE electric coolant pump function. Not familiar with the code either. I'm a lot of help.. .
  5. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Have you ever swapped out the pump or thermostat?
    I did our 2010’s when it had 180k miles on it and I noticed some building resistance in the motion of the impeller.
    Is the engine coolant level stable?
    Good luck and keep us posted (y).
