cold start knock/rattle fixed
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by BKS in IN, Jan 23, 2020.
  1. BKS in IN
    BKS in IN Junior Member
    47
    17
    Indiana
    2013 Prius v wagon
    Hello, new to the forum, but have read a lot of threads during my search of my problem with the Prius V. My wifes 2013 Prius V we purchased new, it has had all maintanance done at the local Toyota dealer since new. It has 149,290 miles on it, uses no oil in between oil changes, and has had no problems until this winter, when it developed the dreaded cold start knock/rattle within the last month. I read a lot of the posts about this problem and watched many videos including the one by nutzandbolts?? I am very mechanically inclined and decided to tackle the EGR system and intake manifold cleaning myself as I cant see paying the dealer what they would charge to do the job.
    So yesterday I tore it all apart, and started cleaning the buildup out of everything. it wasnt really too bad for the mileage, but did have the milky oil sitting under the throttle butterfly. The cooler was the worst of course, so I corked one end and poured lacquer thinner in it and let sit overnight. The manifold I could see had some build up in it, so I got a tub and filled it with hot water and Dawn and let it soak several hours, then dumped and repeated.
    I then pressure washed both this afternoon and was happy with the outcome, so then started putting it all back together. I did make note that my manifold is the newer one, 17120-37054, so Toyota's claim that a new manifold will solve the problem is not true. After several hours of reassembly and refilling the coolant (I chose to drain the coolant from the system to avoid clamping all the lines and still loosing some when the lines were taken off), I got to the point where its like, OK, lets start er up and see what happens.
    I am working in my shop where its 55-60 degrees, so not really a cold start. I start it up and still have the knock/rattle/rough idle, just not as bad or loud. I pushed on the gas pedal slightly to see if that would help, and it was very non-responsive. I then try pushing it more, and more, and was like dang, this aint good, it barely revved up.
    It seemed like it was only running on 2 cylinders, so I pulled all the plugs out so I could compare them to each other, as if one cylinder was not firing, the plug would be wet, or black. But all the plugs looked the same. So now I am baffled and need some insight on what to try next. I cleaned the EGR valve and just reinstalled it. Can someone tell me if these symptoms would be from the EGR valve not opening or closing when it should? I took it apart as much as possible and cleaned it and with the solenoid off, i could push it open and the spring would push it closed with no problem, but maybe the solenoid is bad? Needless to say, I see no way of telling if the EGR valve is opened or closed while its running, and not sure when its supposed to be in either position.
    Or did I miss doing something I should of? or forget to plug in a sensor? I checked many times to see if I got them all, but them buggers can hide really well sometimes. Luckily I waited to put the cowl/wiper assembly back on, so its not in the way if I need to get back in there.
  2. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Just to give some more info, the wife drives the car 5 miles to and from work. The cold start knock/rattle is happening every day now, started out just being a time here and there. It hasnt been run for less then a minute and then sits over night like most people are saying when it happens. Oil level is fine and looks clean, antifreeze is not going down, this should rule out a head gasket? the car is parked in the garage every night, and the garage is under the house, so it hardly ever gets below freezing in it.
    49,384
    just a thought, could it be the headgasket?
    Tim Jones, m.wynn and Mendel Leisk like this.
  4. Ivan White
    Ivan White Junior Member
    70
    There is a newly designed EGR. Not sure you can really clean it without completely taking it apart. I just installed the newer version EGR and a totally recleaned EGR cooler and have no problems.
  5. bisco
    49,384
    who knew?
  6. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Whats the part number of the newer egr valve? I couldn't find that in my searches.
  7. Ivan White
    70
    New part number is 25620-37120. It comes with instructions on how to extend the reach of the electrical cable to plug in.
  8. Mendel Leisk
    38,649
    Interesting. Old part number is 25620-37110. This is mine:
    I should have taken more complete pic.
    Can you post the instructions? Something is modified, maybe the black plastic housing, requiring greater cable reach?
  9. Mendel Leisk
    38,649
  10. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Well that's the number on my get valve. I did take it apart, all except taking the spring clip off to remove the plunger.
    #10 BKS in IN, Jan 24, 2020
  11. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Egr valve, darn auto correct.
  12. Ivan White
    70
    It's not significant. Just cutting a cable tie and wrapping some heatproof tape after you extend the cable to the slightly larger EGR valve.
  13. Ivan White
    70
    The more serious issue is if you want to spend the additional money for the supposedly new and improved EGR valve vs. better cleaning of your old valve . There are some instructions on this forum and on YouTube about how to dissemble and really clean the old EGR. But you have to get inside the valve.
  14. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Put new plugs in the car and got the belly pan cover deal put back on and took the car for a,ride and it ran great. I parked it in the barn so I can test a,true cold start tomorrow morning and see if it acts up.
  15. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Car started and ran great after being in the cold barn all night. So can I change the title to problem solved?
    dig4dirt likes this.
  16. Mendel Leisk
    38,649
    I think I managed to clean the valve completely without removing the black plastic cap. I was having troubles breaking loose the #@%$&! screws, and decided to let them be. I'm sure it's much easier with the valve component removed, but I managed. I just gently pried up on the valve, cleaned around the flange. Cleaned the other end thoroughly with brushes, and ran a lot of brake cleaner through.
    Too, I've heard it's a bit of a Pandora's box once opened? Some people have had problems getting it properly reassembled?
  17. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    So here is my theory on what's causing this problem. The egr system design is faulty, which causes carbon buildup thru out the whole system, including the spark plugs. But the rattle/knock cold start and rough idle on cold start doesn't appear until the spark plugs get carbon buildup on them causing misfired on 1 or more cylinders. So a quick fix would be to clean or replace the spark plugs. But unless you clean the egr system, its just a matter of time before the plugs get carbon buildup again. So cleaning the whole egr system and the plugs, or replacing the plugs is the long term solution. Like my original post said, this just started happening on our Prius this winter, after 149k miles.
  18. BKS in IN
    47
    17
    Indiana
    2013 Prius v wagon
    Just to clarify, our 2013 Prius V has the newer 25620-37120 egr valve and the newer 17120-37054 intake manifold. So not sure if these most recent designed pieces allow 149k miles before the problem arises compared to earlier versions have the problem much sooner?
  19. Mendel Leisk
    38,649
    My favourite theory: unclogged EGR is paramount to keeping combustion chamber temps at spec, and when EGR clog, temps go up head gaskets fail.
    Typical failure between cylinders 1 and 2, involving coolant leak into cylinders.
    Toyota seems to have given up on the "improved" intake manifold. Not sure what the valve revision would be, might be incidental. Doubt it will solve the issue.
    #19 Mendel Leisk, Jan 25, 2020
    m.wynn and BKS in IN like this.
  20. Ivan White
    70
    The -37120 is the new valve part number. the -37110 is the old.
