Cold start knocking (video)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DJ Q, Jul 21, 2021.
  1. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Any help on this is greatly appreciated.
    Oil always changed on time
    Vehicle at 110,000kms
    Recently changed spark plugs to try to counter this
    Sent vehicle for EGR to be cleaned though I don’t think they did it properly because I got back the car in less than 40 mins including other maintenance.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Proper cleaning takes at least 3hrs.When knocking occurs add some acceleration to rid noise faster.
  3. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    After checking some other threads on the forum, they suggested that the car could be burning oil... checked my oil and it was down to the second dot on the stick!! Rectifying that today.
    Is the EGR cleaning the only thing suggested/recommended for this??
  4. tankyuong
    1,555
    660
    Central MO
    Oil catch can also
  5. Mendel Leisk
    38,707
    Plus a leak-down test, if the knocking persists.
    Bear in mind the intake manifold is the last leg of the EGR circuit, needs cleaning too. A casual request EGR cleaning, and the car’s back to you in 40 minutes, says to me you still have a job to do. I’d strongly recommend DIY, more info in “bad flywheel” link in my signature.
    All said, 110k kms is pretty early for head gasket to let go; getting on the cleaning ASAP you may be out of the woods.
  6. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Thank you kindly for all your input.
    I was honestly dreading the DIY because I need to buy a few things and it's so much work :cry:
    But say what... Anything to keep Priya going.
    Mendel Leisk and bisco like this.
  7. bisco
    49,439
    say what? life goes on bra, have a red stripe!
  8. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    There’s a T-SB on rattle upon cold soak. Check with local dealer regarding warranty eligibility…
    lizardskin likes this.
  9. Tekken
    Tekken Member
    257
    77
    Los Angeles, California
    EGR cooler clean took me 2days. 3hrs to take it apart, more than 24hrs to soak-in the EGR cooler and after that, I took it to car wash spray with water compressor and 4-5hrs to pull it back.
  10. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Sorry but I'm not sure what you mean. Also I bought this car RORO so they won't honor any warranty here.
    This is not motivating me to do this lol
  11. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    (I don't know what RORO means)?
    USA Toyota dealer service departments should be able to pull the Technical Service Bulletins.
    (Applicable to USA 2012 - 2015 PHV, 2012 - 2016 "V" yes they capitalized it but I interpret as wagon, and 2010 - 2015 Prius).
    T-SB-0103-12 Rev2 which was updated September 8, 2016.
    "MIL "ON" DTC P2111 and P0A0F After Cold Soak" ambient temp below -23 F (-5 C)
    Replacement intake manifold:. 17120-37091
    Authorized Label:. 00451-00001-LBL
    Calibration IDs (respective IDs/years also apply to 0027-16):
    2010 Prius 34715700
    2011 Prius 34728500
    2012-2013 Prius 34734400
    2014-2015 Prius 834754200
    2012-2013 Prius v 34725500
    2014 Prius v 34751200
    2015-2016 Prius v 34758100
    2012-2013 PHV 34740200
    2014-2015 PHV 34755100
    (Applicable to 2010, 2012 PHV, 2012 V, 2010 - 2012 Prius)
    T-SB-0027-16 March 31, 2016 supercedes T-SB-0075-13
    "MIL "ON" DTC P0401 and/or Rattle After Cold Soak"
    Replacement EGR Valve Kit:. 04004-58137
    EGR Cooler Gasket 1:. 25685-37010
    For VINs prior to:
    Prius JTDKN3DU#C5491168
    Prius V JTDZN3EU#C3159675
    Prius PHV JTDKN3DP#C3023590
    So could it be intake manifold design AND/OR EGR valve design causing trouble?.....
    moto g(7) power ?
    #11 jzchen, Jul 23, 2021
  12. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Wow that's very detailed. Wish I understood most of it.
    Two things to note, based on what I could decipher from that very technical post:
    1) I'm not in the US
    2) Ambient temperature does not go below 22 C here.
  13. Siward
    Siward Active Member
    296
    124
    Toronto
    After the EGR cooler, EGR pipe, the next thing would be to clean or replace the intake manifold gasket. Or at least that's what this video says:
  14. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    They're each 10 pages long, but have a Copyright at the bottom of every single page. I don't dare post it because of this.
    22 C translates to 72 F. That's warm. Hmmm....
    Did you get a check engine light?
    moto g(7) power ?
  15. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    No check engine related to this issue.
    Just the dreaded P0A80. So yeah I need to sort that out too.
    And no, 22 is pretty cold here.
    The lowest I've seen is 19 in the mountains.
    Our days average 32-34
  16. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    Oh and RORO means roll on roll off.
    The car was imported from Japan.
  17. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    That helps. Then I'm not sure my T-SBs apply because those are USA market specific....
    moto g(7) power ?
  18. douglasjre
    douglasjre Senior Member
    1,872
    651
    Orlando, FL
    You haven't done all the diagnostics. A weak ignition coil can do this as well. In fact you haven't done any diagnostics
  19. DJ Q
    DJ Q Junior Member
    52
    24
    Trinidad & Tobago
    I've done all I know to do, hence this thread.
    I'm not a mechanic nor do I claim to know everything about this car. (y)
    How do I diagnose a weak ignition coil?
