Cold starting
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, Feb 5, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    I'd read on this forum once, that the Prius was a cold weather favorite in Ulan Bator Mongolia, because it always starts in -50C or colder temps. I think that's due to the low viscosity synthetic oil and the way the gasoline engine is started.
    It was -33C outside this morning, and my car started fine without the block heater being used.
    I've never been one to err on the side of caution; I put a lot of faith in synthetic winter oil.
    My Gen 3 had synthetic 0W-20 engine oil, and it always started fine in any temperature, even down to -35C.
    My Gen 5 uses 0W-16, so I don't see the need to heat the engine before starting. Someone will call me crazy for sure, but I never plugged in my Gen 3 block heater, and it was in pristine condition 12 years later.
    Jack90210 likes this.
  2. Mendel Leisk
    40,584
    So, when are you going to use the block heater?
    The "it" being the block heater?
  3. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    When I see some evidence that I need it.
    Not just for the sake of doing it.
  4. Mendel Leisk
    40,584
    I'm setting out for the dentist just after noon. It's -6C here now. I'll be plugging our 2010's block heater in around 10 am. I use it thus year 'round.
    For a variety of reasons, I always buy new cars. :)
  5. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    I could dig out the special block heater cable out from under the rear deck, and use it to plug in my block heater, like a good little boy, but after 20+ years of driving with synthetic oils, I've never seen a need for it.
  6. ChapmanF
    17,347
    Having a 23 kilowatt 'starter motor' doesn't hurt in winter temps....
  7. bisco
    51,154
    Wouldn’t the block heater speed warm up and reduce pollution?
    are they available in Mongolia?
  8. Trollbait
    12,351
    Those using block heaters year round see less gas use.
  9. Trollbait
    12,351
    They put lifts on gen1s there, Getting a block heater probably isn't an issue, but more with powering it.
  10. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    And more electricity use.
    Ever think of that?
  11. Mendel Leisk
    40,584
    From this site, with my electricity rate ($0.1097/kWh), block heater wattage (400), 2 hours use, in Canadian dollars:
    Electricity bill calculator | Energy cost calculator
    Roughly 9 cents per use.
    Other things to think about:
    Improved fuel economy, especially on shorter trips
    Faster cabin warm-up
    Less wear-and-tear on the engine (cold-starts are the toughest time for an engine)
    Second to last link in my signature has more info, specific to 3rd Gen Prius, but some general as well. On a phone turn it landscape to see signatures.
    #11 Mendel Leisk, Feb 5, 2025
  12. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    It wouldn't have hurt to interconnect the charging circuit with the block heater.
  13. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    I don't doubt that the lube helps, but the real difference is that a Prius starts its engine using torque from its motor-generators which are much more powerful than the starter motor in any other car. Also those motors are backed by a much larger battery.
    If that starter can bend connecting rods in a hydrolocked engine, you bet it's gonna spin a good start on a healthy engine in extreme cold.
  14. Mendel Leisk
    40,584
    @Paul Gregory, I don’t think it’s been clarified: considering you’ve got the plug-in, you’re starting in regular “hybrid mode”?
  15. ChapmanF
    17,347
    I'm not sure whether the rods get bent by MG1's torque alone, or if that happens when some other cylinders fire too, or at least some good flywheel momentum builds up before hitting the flooded cylinder..
    We know from a recent thread that there can be some cases, at least, of genuine hydrolocking where the ECU tries to crank and just gives up and sets P0A0F-238.
  16. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    Since I try to keep a charge in the battery, it always starts in EV mode.
  17. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    But do you compare the costs of using the block heater year around against the supposed fuel savings?
  18. Mendel Leisk
    40,584
    5 days a week, 2 hours usage per, year ‘round, for me, the cost for would be $23.40 CDN. Out-the-door cost of an inexpensive wine?
    I should maybe note: our usage is about a 5th of that; we typically use the car about one a week. Appreciate that’s unusual.
    Besides gas saving, have you ever priced short blocks?
    Anyway, you go your way, I’ll go mine. I believe new cars sold on the prairies, it’s pretty much mandatory to have block heaters installed before sale. Maybe for some reason?
    #18 Mendel Leisk, Feb 6, 2025
  19. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    If I had free power, I'd want to keep my engine at a stable operating temperature at all times.
    That's what they do with large scale backup generators.
    But doing so seems to me like it's bordering on OCD.
  20. Paul Gregory
    1,508
    391
    Alberta
    2024 Prius Prime
    XSE
    As soon as I see some actual benefit in doing so.
