Cold temp droped tire pressure 7lbs
Discussion in 'Gen 2 Prius Fuel Economy' started by nickfromny, Oct 10, 2008.
  1. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Presure back up to 42f/40r and mph is back up over 50mpg. Winter is comming.
  2. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    yet another reason to think about Nitrogen. My Tire pressure is exactly what it was when filled. 42/40. 10K miles now not a single pound difference than when set.
  3. Neicy
    Neicy Member
    834
    Wakefield, MA.
    :Cry::Cry::Cry:
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    TP is something you should check on a weekly basis no matter what the season
  5. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Ignoring the possibility of a leak, PSI is guaranteed to drop as air temperature drops.
    Warning Tech Alert
    - The relevant formula is P*V=N*R*T where T is absolute temperature (P is Pressure, V is Volume, N*R is the amount of air in the tire). So a 50 degree drop in temperature results in approximately a 10% (4 PSI) drop with dry air (or nitrogen - no difference). Moisture in your tires can cause a slightly higher drop in PSI. (sorry, I'm an engineering professor and can't help myself)
    JeffD
  6. richard schumacher
    7,663
    1,038
    United States
    That means (1) whoever mounted the tires did a good job, and (2) the tire temperatures were the same at the two measurements. The nitrogen fill had nothing to do with it other than being a relatively dry and inert gas; air, argon, or sulfur hexafluoride would have worked just as well :_>
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Man! Don't let the cat out of the bag with that one! If everyone finds out about it.....then they'll all want it......
    Nothing to see here....keep moving....
  8. richard schumacher
    7,663
    1,038
    United States
    They can clamor all they want, but it's an extremely efficient greenhouse gas so it will never be legal for tires.
  9. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    This time of the year, I check my tire pressure every 1.5 weeks not longer than 2 weeks. Only a couple of my tires are dead on the spot where I want it to be...and I add just a little air on the rest. Keep it this way and your tires will last longer too. I am a little over 14K now and tires still look great.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    +1. Living in a warm climate does have some advantages, other than big bugs.
    Tom
  11. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    My TPMS light came on last week. The cold weather and the fact that I haven't checked my tire pressure since August both played a role. I pumped them back up to 38/36 and all is good. I'm putting on winter tires in the next few weeks anyway. I'm gonna have to live with that pesky light all winter long.
  12. nickfromny
    309
    24
    Binghamton, NY
    Black Duct tape will hide it just fine.
  13. rpg51
    rpg51 Member
    200
    Vermont
    Yea, my light is on all the time now. Doesn't bother me in the least. Just another little tiny light up there on the dash like the others.
