Cold temperatures and battery longevity
Discussion in 'Prime Technical Discussion' started by Prashanta, Mar 27, 2017.
  1. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    I live in Canada Land where outside temperatures are often below -20*C in the winter. Once I get my hands on this car, I will have to park it on my driveway. My worry is that the frigid temperatures might cause permanent damage to the battery. Even if battery temperature is managed while car is plugged in, for about 8 hours/day, it would be parked at my company parking lot where I don't have access to a plug. Is this something to be worried about?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The lithium battery -may- have a problem with very cold temps. From what I've read so far -20C should be ok.
  3. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    5 winters in Minnesota with temperatures that could at times were never a issue for my PHV... and that older generation of plug-in Prius didn't have a battery-warmer.
    I don't see any concern for my Prime here either.
    Prashanta likes this.
  4. Primetoronto
    Primetoronto Junior Member
    I live in ontario..my 2010 prius is running smoothly with 260k Kms ..the Prime should be okay with very cold weather.
  5. Prius from Dad
    Prius from Dad Senior Member
    724
    1,115
    Toms River, NJ USA
    Your battery should be ok, but your EV miles will be low, due to the cold. At those temps you probably will not get the 25 mi. advertised. My guess from my experience is you will probably get in the teens EV. There is a traction battery warmer setting that should help some.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    also, when the temperature is -10 degrees C or below ICE will kick in so your EV MPG will suffer
    Prashanta and bisco like this.
  7. john1701a
    12,755
    5,245
    57
    Though, it will still be impressively above what a regular hybrid could deliver.
    priuscatprimeguy likes this.
  8. bisco
    49,488
    i would contact toyota before purchasing, don't trust the dealer to answer honestly. i think canada gets a special battery warmer.
  9. Zythryn
    Zythryn Senior Member
    6,258
    4,258
    Cold, in general,is better for a battery's long term health.
    However, there are limits.
    I would check the manual, and Toyota corporate to see what they recommend.
    As an example, Tesla warns against leaving the car unplugged in very cold temps for 24 hours straight. I forget the number, but I believe it was somewhere around -30C.
    In MN, I haven't had an issue in 6 years of driving Tesla vehicles. I know your weather can get colder than ours though.
  10. Tideland Prius
    16,155
    Should be ok down to -30°C but I'm not 100% sure. It really depends on the battery chemistry that Toyota chose for the Prime.
    I know the NiMH batteries are fine even with a cold soak but IIRC, NiMH are better at extreme temperatures (in terms of stability and operation) than Li-Ion. I've operated my vehicle in temps as low as -46°C.
    Also, the car will protect itself. If it'll provide reduced power (or the car won't start) if it's too cold. During the day, the sun will at least provide a little bit heat (Feb/Mar). Also, it'll take a while for the battery temperature to reach -20°C even when the outside temperature is -20°C.
  11. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    You should not have to worry about that....BMS have parameters to deal with cold....Heat is what is much harder for BMS to control
    #11 Samprocat, Mar 27, 2017
  12. Trollbait
    11,560
    First off, if your job's parking lot doesn't have outlets for engine heaters, and people aren't getting stranded because their car got too cold during the day, the Prime should be fine.
    The risk for Li-ion batteries at freezing and lower temperatures is during charging. Crystals can form that reduce capacity, and the damage is permanent. To avoid this, the battery needs to be charged at a really low rate until the regular resistance of the process heats it up, or simply heat the pack up by some outside means.
    The Prime has a battery warmer for this purpose, and it has extended operation cycles in cars sold in Canada and Alaska. Then Toyota isn't new to properly managing traction batteries, even Li-ion ones. There should be safeguards protecting the battery in place beyond the the warmer.
    Worst case, the car won't start out of self preservation. I don't see that as likely, and other cars probably won't start under the same conditions. It is something I would only be concerned with if the car wasn't plugged in overnight. At your work's parking lot, the battery is going to be arriving warmed up, and it is a sizable mass, so some time will pass before if starts to approach freezing temperatures.
    Realistically, I would count on just having hybrid operation during the winter. Better to be surprised with some EV miles than disappointed with a new car.
    Prashanta and priuscatprimeguy like this.
  13. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    This. The available capacity will be lower WHILE the battery is cold, however.
    That will go back up as it warms.
  14. sylvaing
    sylvaing Senior Member
    1,045
    429
    Reviving this old thread because this subject is still unclear for me, especially regarding this comment.
    "The risk for Li-ion batteries at freezing and lower temperatures is during charging. Crystals can form that reduce capacity, and the damage is permanent”.
    How about Regen braking, which is basically the same as a brief (or not so brief when going downhill) charging cycle? How does that affects the Prime's battery health?
    At below freezing, that 10 minutes preconditioning isn't enough to raise the battery pack temperature to above freezing. My Model 3 will completely prevent Regen braking when the battery pack is below freezing, but so far, I haven't seen that happening in my Prime.
  15. Tideland Prius
    16,155
    The issue is that Toyota doesn’t indicate how much regen is occurring on the Energy Monitor (e.g. like what Ford does with the size of the arrow going from the wheels to the battery). It could be 0.1A and it’ll show the arrow going into the battery.
    Toyota is a conservative company (as evident by the slow charge rate of the bZ4X) and the Prime is warranted for 10 years/240,000km on the battery (2020 and later) so you can be sure they’ll program the car to ensure that the battery lasts that long.
  16. sylvaing
    1,045
    429
    Hybrid Assistant does show the power going back and I don't see any difference between -5°C and +20°C. Mine is a 2017 so "just" 8 years/160,000 km.
    Tideland Prius likes this.
  17. sylvaing
    1,045
    429
    I'm now keeping the car plugged so the battery heater can do its job and make sure the battery doesn't get below freezing.
    Louis19 and Tideland Prius like this.
