Cold Water leaking onto Passenger Floor
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ggischia, Jul 17, 2010.
  1. ggischia
    ggischia New Member
    South Carolina
    Dramatic gush of clean very cold water when making a left turn, AC always on as it is high 90F here in SC in July. No smell to the water, seems clean like from AC. Comming from center, "tunnel" area. Just above where passengers ankle would be, against the carpet. One time on long left turn (round-about) a blowing sound was heard also.
    Any ideas. A/C otherwise working fine.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Plugged drain for the AC.
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Get it taken care off soon or you will have mold growing in your AC, particularly in your SC climate.
    Could possibly be a loose drain hose but that would normally be more of a continual drip than an occasional gush.
  4. doctorman
    doctorman Member
    202
    34
    NY 11020
    "Plugged drain for the AC"
    can some one elaborate on this...
    can a regular mechanic fix this?
    is it specific to prius?
    do I have to go to dealer?
    can I do it at home..
    my car started to stink ....
    please help .. any info is appreciated.
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    just like your home AC, there's probably a little pump to pump away the water that collects on the cooling coils to a drain, or even outside. In cars, often there's a little hose that's connected to the bottom of the cooling matrix housing.
  6. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
  7. Joe166
    Joe166 New Member
    720
    96
    South Florida
    I once had a car where this happened and they couldn't find a stoppage in the lines. It turned out that the drain hose was improperly placed and the bottom of it was facing forward so that when in motion, the air would push into it and force the water back into the fan area and then into the interior. It just took a pair of cutting pliers to cut an angle at the end of the hose to make the hole face toward the rear and it was fixed.
