Cold weather, air density, and drag
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Dec 17, 2022.
  1. bwilson4web
    15,513
    The air density if a function of pressure and temperature: Earth Atmosphere Model - Metric Units
    The red formula shows the air density is inversely proportional to the ar temperature. Cold air is more dense.
    The air drag source: The Drag Equation
    Every vehicle is affected by denser air that increases drag. A rule of thumb, above 45 mph, aerodynamic drive is a primary force which is why every vehicle has lower mileage. But since the drag is proportional to velocity squared, just slow down and the efficiency returns.
    One thing I forgot to mention is with the colder, winter temperatures, tire air pressure will decrease. So it is time to inflate the tires to your desired pressure. I typically run as maximum sidewall pressure to minimize rolling drag.
