Cold weather engine problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cubbyg, Feb 27, 2007.
  1. cubbyg
    cubbyg Junior Member
    57
    After start-up in the early morning, I noticed that the engine was running rough like a missfire. The car shook and shuttered at a stop while the ICE was warming up the resevoir for the days driving. I reported it to the Dealer. They ran a diagnostic and not to my surprise, since there were no check lights, they did not come up with any "codes."
    The next morning the same thing happened. So, I returned and talked to the Service manager and the shop foreman. They both concurred that I should take a long drive and hopefully the computer would generate some history. Well it is a month later and it is still happening. I called Toyota corporate and they referred me back to the Dealer. The service Manager drove me in a new Prius and the same thing happened. I called Corporate back with the detials of the meeting and they will not refer it to engineering. They said that it is up to the dealer to call for more technical information. For now they tell me that "All Priuses do 'THAT' "
    Are they blowing green smoke up my tail pipe or is there a technical reason for this occuring. I don't like mechanical problems hiding behind the mystic of the hybrid engineering.
    Would appreciate all your inputs. Thanks
  2. richard schumacher
    7,664
    1,043
    United States
    Eh. That's common when they're cold. If it starts running rough all the time, that's a problem.
  3. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(cubbyg @ Feb 27 2007, 08:54 AM) [snapback]397232[/snapback]</div>
    Apparently this is normal in the first (or is it the second) stage of Prius operation. Do a search for "5 stages" of Prius operation. I just tried, but the first link that I tried was obsolete. I know a new one has been created, but I haven't found it yet.
    Dave M.
  4. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    The "five stages" article is on hobbit's website, http://www.techno-fandom.org/~hobbit/cars/five-stages.txt
    I'm not sure if this is normal. During last month's cold spell, morning temperature was in the teens for the entire week, my engine behaved the same way as you described one morning. And it never happen ever since. I check the DTC code in CAN-View and nothing show up.
  5. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Is it worse when you shift to Neutral? Remember that any slight
    variation in engine speed causes a roughly 3x variation in MG1's
    speed, and that's a nontrivial mass o' metal to be whipping around.
    _H*
  6. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    While I can't say with certainty that my block heater is the reason, I have never had the symptoms which you describe. I have a timer set so the the block heater comes on for a few hours every morning to take the chill off the ICE and the engine room. I also use radiator blocking (this is the lowest cost mod I have done). My car seems to be happy.
    I have CAN-VIEW and can detect no negative effects from either mod.
  7. hjon71
    hjon71 Junior Member
    98
    I have never experienced this problem. My guess would be bad gas? You might try a different station or a dose of HEAT. I would be concerned if my car did this.
  8. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Mine sort of surges if I'm stopped during the first couple of minutes of engine warmup. Doesn't feel to me like a misfire so much as a change related to power flow...either loading the engine by charging the battery or suddenly unloading the engine after supplying a charge. Come to think of it, that hypothesis could be checked by keeping the energy monitor displayed during warmup. Maybe I'll try it tomorrow.
  9. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(ScottY @ Feb 27 2007, 01:04 PM) [snapback]397423[/snapback]</div>
    Thanks for reminding me/us of that link. I thought I had it bookmarked, but maybe that's on my computer at home.
    Dave M.
