Collision Avoidance Radar?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CTitanic, Mar 26, 2014.
  1. CTitanic
    CTitanic Member
    153
    South Florida, FL, US
    Has anybody found an aftermarket Collision Avoidance Radar?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I don't see how anyone could market such a product. Just too complex to design and install.
  3. bwilson4web
    15,528
    Several years ago, I found a collision avoidance system based upon cameras. One technical aspect I could never figure out is the claim their single camera system could measure distances. This is not a trivial problem. But when I tried to get details and possibly buy one, they backed off. They were looking for people with an auto repair or after market service center with bays to install their system.
    -1- Don
    1,247
    434
    Chester, Virginia
    :)I'm impressed with the Toyota's PCS (pre-collision system) and DRCC (dynamic radar cruise control). Some things are a factory only option.
  5. CTitanic
    CTitanic Member
    153
    Exactly , I found that one but I decided to check here before contacting them.
  6. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Does that aftermarket system claim to apply the vehicle brakes (same as the OEM Toyota system does) if it calculates a collision is imminent?
  7. ou812
    ou812 Junior Member
    40
    My wife, not kidding.
    xliderider likes this.
  8. xpcman
    1,302
    295
    I found the following:
    The Toyota Prius v hybrid wagon offers an auto-braking system that performed so poorly in tests by the federal government's National Highway Transportation Safety Administration that the Insurance Institute didn't even include it in its own tests. The Prius v failed to meet NHTSA criteria for collision warning -- let alone automatic braking -- the Institute said, so it didn't meet the minimum criteria to be included.
    Toyota spokesman John Hanson explained that Toyota's system was designed before NHTSA had announced its criteria for collision warning systems. Also, Hanson said, the Prius v'ssystem is an inexpensive technology designed to minimize, but not prevent, collisions while being affordable in a non-luxury vehicle.
  9. CTitanic
    CTitanic Member
    153
    No, it just alert you.
  10. hill
    8,195
    How does the v's system differ - if at all - from the advanced package that was first offered on the 2010 Prius
  11. c4
    c4 Active Member
    607
    51
    Distance estimation with a single lens is actually easy: for example, on my DSLR, I can estimate distance simply by focusing my lens and reading the distance off the scale.. Depending on the lens and the distance, these readings can be quite accurate.. Now of course, you have to pick a lens with an appropriate focal length and shallow depth of focus (wide aperture, which normally = $$$), and the accuracy of the measurement is going to vary depending on the distance (better the closer the object is, worse as the objective is farther away).. The technical challenges are autofocus speed and accuracy, and the "intelligence" of the software needed to determine what in the image to perform autofocus on, but it would certainly be within the realm of possibility to design such a system.. It would however, be much simpler and cheaper to repurpose a commercial laser ranging module.. The software would then be a direct rip-off of the radar code..
    Big problem with anything that requires optics though is keeping the optics clean; radio-frequency-based systems like radar don't really care if there's some dirt on the radome..
  12. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    I wish Toyota's PCS would perform like the Subaru's EyeSight.
  13. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Toyota apparently didn't design the Prius PCS to bring the car to a full stop like the A-PCS found in the Lexus LS and this was done on purpose because they "didn't want to take too much control away from the driver" (their words, not mine). Makes no sense to me but it is what it is.
  14. CTitanic
    CTitanic Member
    153
  15. ny_rob
    1,968
    813
    L.I.- NY
    $800 for something that just beeps when closing on the vehicle ahead of you?
    That seems way expensive to me...
    xpcman likes this.
  16. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Sadly, no aftermarket offering can compete with integration the factory option provides.
  17. cproaudio
    2,401
    759
    CA
  18. c4
    c4 Active Member
    607
    51
    $800 is actually pretty cheap when it comes to all the highly specialized video processing that this system uses.. It's probably cheaper than the component cost of Toyota's radar system, which you're actually paying a whole lot more more because you have to get the highest level package, which in Canada is an over $8000 "upgrade", which in terms of the higher priced add-ons really only gets you the radar and the crappy JBL audio and nav system; you don't get the other nice to have features in the "intermediate" packages like LED headlights or alloy wheels, etc... And although it doesn't integrate with the brakes like the Toyota radar (probably some regulation that prevents aftermarket systems from touching safety systems like brakes), it actually does more than just collision avoidance- there's lane departure, pedestrian detection, even an option for automatic high-beam headlight control..
  19. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :)A lot of new, high technology factory options available now. Best to research them and decide if they're the right option for you versus cost. The 2012 - 2013 Prius Plug In Advance is a good example. I like options and technology. The Advance model was a easy choice for me, I could justify the additional cost. I understand Toyota's thinking with the 2014 Plug In Advance without Advanced Technology. Lower cost, a few less options. Those wanting a 2014 Advance with AT will find them hard to find, especially in color of choice. With limited numbers, negotiating a good price will be tough. Anyone wanting all the advance technology options would be wise to consider a used 2012 - 2013 model, selling at bargain prices.
  20. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Considering how options don't add much to the resale value of the car, I'm sure you can trade your Prius for a used one with ATP for $800-1000.
