Combination Meter Replaced, lower MPG
Discussion in 'Gen 2 Prius Fuel Economy' started by HermesDavid, Sep 8, 2016.
  1. HermesDavid
    HermesDavid New Member
    Irvine
    Hello,
    Has anyone received lower mpg after they had the combination meter replaced? It went down from 43/44 to 39. I have to feather the throttle just to get it to 40.9.
    Note: Had it installed at a Toyota. Using 10w-30 Semi-Synthetic. New tires. 190k miles.
  2. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I'd say give it a few tanks of gas...if they cut off power, the system may take time to recalibrate. After that we need to know if real MPG has changed or just on-screen MPG.
    What was the bill in case I have to too $$?
    PS- 10w30 is a little too thick think you want 5W30
    PPS- New tires almost always cuts your MPG as the tread is thicker, so your car thinks you are going less revolutions for the same actual distance. See TireRack.com discussion of observed MPG physics related to new tires.
    #2 wjtracy, Sep 8, 2016
    Kevin_Denver and srellim234 like this.
  3. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    wjtracy hit the big ones. The Combination Meter is not the likely cause of your mpg hit. Most likely causes are:
    Tires: Different tires have different amounts of rolling resistance. If you switch from a tire with very low rolling resistance to one higher, this can cause a large mpg hit. Tires have higher resistance for the first few thousand miles as they break in. Also minor is they are slightly larger in diameter, so your car won't think you've traveled as far.
    Computer Reset: It's hard to say exactly, but my Prius also takes a small mpg hit for about 50 miles whenever I have to disconnect the battery.
    Oil: In the US, the recommended oil is 5W-30. Running 10W-30 could cost you a percent or two in fuel economy from the extra resistance of the engine working against the thicker oil.
    skylinedrive804 likes this.
