Combined GPS and Mini-Scanner data
Discussion in 'Gen 2 Prius Technical Discussion' started by bwilson4web, Sep 3, 2007.
  1. bwilson4web
    16,353
    Hi folks,
    I've recently combined GPS NEMA with Graham Davies Mini-Scanner data on a trip from Huntsville AL to Knoxville TN. This allows using GPS altitude along with the fuel consumption data calculated from the Graham scanner:
    The same data in metric:
    This first detailed chart shows the impact of coming to a stop. To handle the problem of dividing 'distance/fuel' with the engine off, I carried forward the last MPG value. The Prius MFD shows "99.9" in such cases although math tells us it should be a very large number. The draw back with this approach, the carry forward of a lower 'distance/fuel' rate, is it suppresses some of the effect of ICE off. This said, it also shows the challenge of coming to a complete stop with the impact of acceleration on the average MPG:
    Regenerative braking is better than ordinary brakes but it is not terribly efficient. Many efficient drivers learn quickly to minimize energy regeneration.
    In contrast, hills do a much better job of energy preservation. Climbing the hill burns more fuel but it substantially increases the potential energy and pays it back on the downslope:
    One interesting aspect is the GPS ground plot led to finding a more Prius friendly route headed east from Huntsville:
    Yesterday I tested the original and new route from south Huntsville to Gurely AL and found they took the same duration, 30 minutes, but:
    • 21.6 mi, 58.6 MPG - original route
    • 15.6 mi, 61.3 MPG - new route
    This repeats the pattern of finding direct, Prius routes at slower speeds but identical elapsed times. Route planning pays dividends.
    My inexpensive, $50, GPS has a lot of altitude wander in the first minute. But after the first minute, it appears to be accurate enough for my studies. I'm working on a program to read both the GPS and Graham scanner data into a single, comma delimited text file for future studies.
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    u should of attached this to one of those you know you've been driving your prius too much threads
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(rigormortis @ Sep 4 2007, 03:07 AM) [snapback]506693[/snapback]</div>
    Bob is our PriusChat data freek. Actually what he's done here is pretty simple as the MiniScanner has a direct data output port on it to hook up to a laptop and save the data. Procedure: turn on lap top, hook up to MiniScanner, start car, drive trip, save data to file, turn off car. Done.
