Coming up on 300,000 miles starting to get some engine noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ktthomas, Sep 14, 2017.
  1. ktthomas
    ktthomas Junior Member
    Ohio
    Hello all,
    My prius is getting real close to hitting 300,000 and I sure would like to get there !! I'm starting to get some engine chatter, sounds like a lifter, when accelerating slowly. If I step on the gas it intensifies and then disappears.
    I am using a bit of oil now too. about 1 quart every 1800 miles. One thing I have noticed is that when I get an oil change I don't hear it until I have driven about 2000 miles or added some oil. The longer I drive on an oil change the more I notice it until I get an oil change again (every 5000). I'm toping off with Pennzoil but that is not what the mechanic uses. I don't know if that matters or not.
    I have never used high mileage oil, synthetic or anything other than basic oil. Mainly because the guy who owned it before me never did so I just kept doing what had worked for him for so long.
    Now I am wondering if I should try a different oil of if there is anything else you would recommend I try.
    Thanks
    amos likes this.
  2. JC91006
    16,470
    8,383
    Change your oil every 2500k miles
  3. maximusdec
    maximusdec Member
    107
    52
    That is the way my car has been for the last 90K miles. No issues. I am closing on 225K now. You will surpass 300K. Mine burns a quart every 1300-1500 miles now. Just fill her up in between oil changes. I use the $10 walmart oil. No problems. It's going to burn it anyways so don't use expensive oil. Like you said that lifter noise appears when the oil gets dirty and I guess thins out in viscosity. So shorten your oil changes to 3K or so. Also I used Mobil 1 once to see if it helps, I think it did but it could also be just in my head.
    amos likes this.
  4. Patrick Wong
    18,198
    6,464
    Why not use 10W-30 oil, at least during warm weather.
    jerrymildred likes this.
  5. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I too seem to consume a good amout of oil between oil changes. I use synthetic and recommend it to anyone who will listen. It's greener for sure and I believe it's just a better product. I use Amsoil which is supposed to be the best out there. I buy it from a dealer who also works on my car. He recommends 10W40 and that's what I use. I also bought a big 5 quart jug of Mobil1 10W40 synthetic at Wal-Mart for like $22. With the synthetic I use a 10,000 mi change interval but I do agree with everyone about increasing the frequency especially if you use conventional oil. I have 251,000 mi on my Prius and I really think the synthetic oil helps
  6. chelvis
    chelvis Member
    83
    49
    Long Valley, NJ
    I am original owner '05, just turned 275,000 miles and have been running synthetic since 100k miles. I burn a bit of oil and have same lifter noise.
    I change oil every 5k, run 5W30 and am aiming to keep it rolling past 300k. If needed I was going to pick up a used engine.
