Commercial airplanes and SKS
Discussion in 'Gen 3 Prius Main Forum' started by phoenixgreg, Mar 21, 2012.
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    I'm about to take to take a trip and it's been awhile since I've flown. I always take my keys and wondered if anyone has ever run into the situation where a Prius fob (SKS) was considered an "electronic device" that could cause interference with a commercial plane's navigation or fly-by-wire devices?
    I searched here and could not find anything about it. I'm probably OK but just wondered since it can't be "turned off".
  2. rcf@eventide.com
    173
    85
    Sedona
    The most important aspect of "turning off all electronic equipment" is making sure it's invisible to the flight attendants, e.g., in your pocket or in the seat back compartment. Until a recent software update, the Droid X cellphone and maybe other Android models had an interesting bug: You could turn it completely OFF (not just "airplane mode") and it would turn itself back on! This happened to me on a flight (out of Phoenix, by coincidence,) and, other than finding the battery somewhat depleted when I removed it from my pocket after landing, there were no ill effects and almost all the flight controls and navigation gear appeared to remain with the aircraft and be operational. A recent news article indicated that the FAA is revisiting the electronics-OFF rule with a view toward liberalizing it.
    If you're still concerned, note that the fob operates on a different frequency from avionics equipment, and I'm pretty sure it doesn't transmit unless it receives a signal from the car or you push a button. Otherwise that tiny battery wouldn't last for years.
    Richard
  3. phoenixgreg
    1,157
    289
    66
    Phoenix
    Thanks Richard. I thought the SKS was always transmitting a signal. So it needs to be in proximity with the Prius to begin sending signal...I did not know that.
  4. billinmd
    billinmd Member
    184
    28
    Bel Air, MD
    2020 Prius Prime
    They typically state that a device needs to be off if it is electronic and has an on/off switch. I wouldn't worry about they key. I travel with mine in my pocket all the time, and I would never think about putting it in my checked luggage.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The SKS part of the fob is a transponder: when pinged by the car, it responds. The button part is a standard transmitter, so each time you press a button the fob sends out a burst.
    SKS fobs can erroneously respond to other signals. Keeping your fob and cell phone in close proximity can cause the fob to respond repeatedly, causing premature battery failure.
    So the two worries about an SKS fob in an aircraft are button presses and accidental transponder responses. Both are unlikely, and both are unlikely to cause interference with avionics.
    Tom
  6. h00ktern
    h00ktern Member
    134
    40
    And if it really comes to fly, no-fly, you can always remove the battery :cool:
  7. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    How likely is this to happen? I keep my phone and key fob in my pocket all the time.
  8. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    I've kept my fob in my purse for coming on 3 years now. I also keep my cell phone in my purse when I'm out of the house. So far the fob's batteries are just fine. So, I'm thinking if it IS likely, the drain on the battery is minimal.
  9. qbee42
    18,058
    3,074
    Northern Michigan
    Toyota specifically cautions against this in the manual. How likely? Who knows. It depends on a number of factors, all out of the user's control.
    Worse case you have to buy a new fob battery; it's not like the world is going to end.
    It is possible for a cell phone to interfere with the operation of the SKS. File this away in the back of your brain, just in case your fob stops working. If that happens, try moving the cell phone.
    Tom
  10. p00kienrayray
    720
    135
    Long Beach, CA
    Great to know. Thanks!:)
  11. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    When I fly, I put my keys in a particular pocket of my briefcase or carry-on and never touch them until I re-enter the parking structure when I return. I used to travel 3x per month back in the '90s and developed a bit of OCPD in my travel prep & procedures. The good thing is that it saved my bacon a number of times ensuring that I always had what I needed on the road.
  12. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I have traveled with my key fob and never had a problem. I am certain that if the FAA had concerns about these the TSA would let you know about it. :eek:
  13. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    I imagine that most commercial flights have at least a few cell phones onboard, in carry-on bags, pockets, etc, that people have forgotten to turn off. They surely produce more and higher energy emissions than a smartkey FOB, although I doubt that they have any impact on avionics operation or aviation safety either. Is there any evidence that low-level EMF emissions have ever caused an aviation safety problem, or just lack of sufficient evidence that they don't? I've heard claims that a cell phone caused an air crash in Peru, but have never seen any evidence.
