Common problem on 2nd prius headgasket at high miles?
Discussion in 'Gen 2 Prius Main Forum' started by reyada4766, Feb 24, 2022.
  1. reyada4766
    reyada4766 New Member
    22
    victorville
    Ihave seen a few 2nd gens that suffers a head gasket leak. Is this common at high mileage? what cylinder is affect the most?
    51,155
    i don't recall reading anywhere that it is common. but all high mile engines will have their share.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    I have been fixing cars for many years (just not many prii until recently) and until I started at this forum a year and a half ago I have NEVER even heard about any Toyota having a head gasket failure.
    Can't day that I have much of anything in the Gen2 forums either. Oil consumption? -lots. Lean run conditions? -sure. General ignition or injector misfires?- a bunch. Not too much else for the ICE.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Overheat the engine bad and it may warp the aluminum head and blow the gasket.
    Quickest way to do that is never change the water Pump belt.
    But based on what I read here with back yard mechanics I would never rebuild a Prius engine. Cheaper and more reliable to just replace the engine.
    In a G2 easier to replace the engine and trans together.
    Lots of used engines out there.
    ANDRAS RIMELY likes this.
