Common Problems with the Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by boostin, Jun 21, 2005.
  1. boostin
    boostin New Member
    Hello. I'm looking to get a toyota prius but i wanted to do some research before acutally investing in one. I wanted to know what the most common problems were with the prius. Is there are precautions i should take? What are the pro's and cons of the prius. Thanks in advance.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    [font=Comic Sans MS:872576247e]Hi Boostin. The full and complete answer to your questions is found on this web site and others you may find referenced here. Please read all threads and all comments. Feel free to use the search function at the bottom of the left column and in the nav buttons on the right of the banner.
    If you have any specific questions you don't find answers to, just ask. Your education awaits you.[/font:872576247e]
    kenoarto likes this.
  3. Tideland Prius
    16,220
    DLC82SV likes this.
  4. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Common problems include:
    1) Everyone wants you to drive to lunch.
    2) You have to tell everyone individually that no, you do not have to plug it in.
    3) You can not stay mad when driving a Prius.
    4) Other drivers are jealous.
    5) You lose report with the gas station attendant you used to chat with every 4 days.
    6) Saved gas money burns a hole in your pocket.
    7) More time spent washing car; no one likes a dirty Prius.
    I could go on, but I really don't like pointing out the Prius' flaws.
    Buy a Prius and then tell us if you can find a downside.
    DLC82SV and danlatu like this.
  5. jo
    jo Junior Member
    Henderson Harbor NY
    I LOVE my Prius except, here is a letter I wrote to Toyota:
    Toyota Motor Sales USA
    19001 South Western Ave.
    Dept. WC11
    Torrance, CA 90509
    Dear Sir/ Madam
    We are a 2 Prius household, and love them. Mine is a 2005 which I purchased in March of 2005.
    Since that purchase, lights functioning properly has been a problem too often. Below is the record of service for light problems
    02/13/2007 AIM HEADLIGHTS AIM HEADLIGHTS ~|~AIM HEADLAMPS
    06/24/2008 R E A R L I G H T R E A R L I G H T ~|~LEFT REAR TAIL LIGHT INOPT ~|~ ~|~R&R BULB
    08/08/2008 F R O N T L I G H T F R O N T L I G H T ~|~INSTALL SOP HEADLIGHT LEVELER SENSOR ~|~HEADLAMP WARNING LIGHT ON, CHECKED SYSTEM, SCANNED MAIN BODY ECU, CHECKED ALL COMPONENTS, LEVELER SHORTED ~|~R&R HEADLAMP LEVELER
    08/08/2008 EXT. BODY ELECTRICAL EXT. BODY ELECTRICAL ~|~50/50 SPLIT W/ WARRANTY ON LIGHT LEVELER
    :09/22/2009 R E A R L I G H T R E A R L I G H T ~|~PS TAILIGHT OUT ~|~ ~|~R&R TAILIGHT BULB
    In addition to these fixed light problems, both of my fog lights no longer work, and now, the amber front marker lights on Left and Right no longer work.
    As I stated before, I love everything else about my Prius, however, not being able to trust the integrity of the lights really bothers me. Fortunately, the cop didn’t give me a ticket when he stopped and notified me that my tail light was out. Why hasn’t Toyota been able to produce this fabulous car with lights that can be trusted?
    If I have to continue to spend so much money to keep the lights working, I’ll have to rethink my loyalty to the Prius. I NEVER had such a problem with any Chrysler, Subaru or Ford (my previous loyalties until I found the Prius) that I have owned in my 54 years of owning and driving cars.
    Their response was by a "trained customer service person", " Gosh, you seem to have some concerns." all said with no apparent sincerity. After speaking with 3 other "trained customer service persons", I was only told that my concerns would be noted. then, "Is there any other concerns you have?"
  6. brick
    brick Active Member
    1,083
    78
    Upstate NY
    You're jerking our chains, right?
  7. Patrick Wong
    18,200
    6,479
    Sounds like you had a problem with the HID headlight leveling system, which is a known weak area. Besides that, you've had more than your share of bulbs burning out. For a five year old car, this does seem a bit unusual. Look at the bright side and be glad that you haven't had problems with the HID light bulbs, transaxle, inverter, traction battery, MFD, steering gear, etc etc. There are many more problems that your car could have had that are much more serious in terms of cost and impact.
    It is possible that the voltage on the 12V bus is higher than it should be, causing the bulbs to have a shorter service life. If you want to look into that you would use a digital voltmeter to measure voltage across the 12V battery when the Prius is READY. The correct voltage is ~13.8V. If the measured voltage is much greater, then that is the reason why your bulbs have a short life. The fix would be to replace the inverter (which is covered by the hybrid system warranty, 8 yr/100K miles.)
    If the voltage is OK, then I would have to assume that your car had a batch of bad bulbs installed, you leave the lights on at all times, or that you are unlucky with regard to bulb service life.
    priusrust likes this.
  8. spinkao
    spinkao New Member
    316
    76
    Czech Republic, EU
    :welcome:. The best thing to do is to look & search around a bit, you will gain some insight (pun intended :)) pretty soon. Regarding some common problems, depends on which generation you are asking. The newest gen III Prius is out for a relatively short time, so it is very much an unknown beast, but as far as the experience allows us to tell the pretty comon problem seems to be that it develops some dashboard sqeaks/rattles relatively soon. Otherwise, it seems to be reliable so far.
    The gen II Priuses are very reliable cars overall; known problems include inverter coolant pump failures after some 100 000 miles (pretty simple and cheap to replace), MFD (Multi-Function Display) failures in the early versions (2004 and 2005) - might be pretty costly to fix if you do it the "official" way with the dealersip, but relatively simple and costless to fix yourself (if you are not afraid of electronic and have some experience with soldering iron).Threads on this issue are floating all around. The 2006 and later cars do not have this problem (it was fixed at the factory). The 12V battery may fail after couple of years and also the HV (traction) battery may fail after some 100 - 200 000 miles, but it is relatively rare. It is not so hard to replace and salvage batteries can be obtained relatively cheaply.
    I cannot tell you much about the first generation "classic" Prius, as I never had that car nor do I know anybody who had. But you can find wealth of information in the "gen I" section of the gen II forum here on the Prius Chat.
    Ruby2005 likes this.
  9. Priusphev2010
    Priusphev2010 New Member
    Michigan
    Biggest problem: you are going to want to drive more.
    Felt likes this.
  10. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Don't invest your money in a high mileage, over 10 year old Prius unless you have deep pockets for the repairs. The repairs won't come often, but when they do.....
  11. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    have you checked the blub fluid level?
    sounds like you are running them without proper lubrication
    replace the bulbs with candles
    cant hurt
    offib and bisco like this.
  12. Mozaffor Sarker
    Mozaffor Sarker New Member
    Australia
    ----Australia----
    Hi There, I am new in this forum. I need some advice from you about my prius 2008 with 164000km. She got red triangle warning light with "!" sign freqently. I am managing her by reseting which I learn from road side assistance. I went to toyota dealer and the told me to replace Hybrid battery which cost around AU$3400. But HV battery recharging well I mean blue to green, till top bar and she runs well to with this red triangle warning light. I am bit confused. Is it really the problem with HV? Thanks
  13. bisco
    49,842
    difficult to say, even in the best of circumstances, but certainly possible in your climate.
    would you be able to ascertain the trouble codes from the dealer?
  14. bisco
    49,842
    have you test driven a gen 4?
  15. bisco
    49,842
    unless you can get it for the right price?
    priusrust and amos like this.
  16. Mozaffor Sarker
    Australia
    ----Australia----
    Here is information from the dealer: INSPECTED AND CONFIRMED WARNING LIGHT ON DESH
    FOUND HIGH VOLTAGE ISOLATION FAILURE
    HV SYSTEM EARTH LEAKAGE - SHORT CIRCUIT SYSTEM
  17. Mozaffor Sarker
    Australia
    ----Australia----
  18. bisco
    49,842
    unfortunately, that covers a lot of ground. from a corroded hybrid battery terminals to a bad air conditioning compressor. you really need the trouble codes and sub codes that were pulled from the obd2.
  19. Mozaffor Sarker
    Australia
    ----Australia----
    It has only one code P0AA6
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    Yep it has a bad hybrid battery. Most likely some cracked or leaking battery modules that have created a corroded path to ground. The system can measure that tiny current path to ground and throws that code ground fault.
    You can reset the code by disconnecting the 12 volt battery that will allow you to continue to drive but there have been some reports of hybrid battery fires with continued driving on ground nag so there's that.
