Commute: EV vs HV
Discussion in 'Prime Fuel Economy & EV Range' started by dave121, Jan 4, 2019.
  1. dave121
    dave121 Junior Member
    23
    Maryland
    2018 Prius Prime
    Hi all. I'm the very happy owner of a new 2018 Prime that drives about 23miles daily on 35mph (20%) - 50mph (20%) hilly roads, and 70 mph highways (60%). I've been trying to understand the best way to use my charge, and take care of / extend the the life of my battery. I've been playing around with manual EV/ HV selection, getting 60-80mpg combined over the trip. If I can make the RT in EV with ~1-2 miles of battery to spare, is it best to use EV for the whole trip (battery on return is ~5%), or am I better off using using HV on the highway, and returning home with a higher charge %, and then topping off to say 80% daily.
    Thanks - Dave
    TGrracie likes this.
  2. schja01
    schja01 One of very few in Chicagoland
    1,747
    1,162
    Chicagoland
    2018 Prius
    Just drive it.
  3. TGrracie
    TGrracie Member
    45
    43
    Duxbury
    2018 Prius Prime
    I mostly keep it in "HV"
    dave121 likes this.
    49,521
    congrats and welcome!
    if you can make it in all ev, go for it. if you can't, warm it up before hitting the highway, then use hv for highway and ev for back roads.
    all the best!(y)
    dave121 likes this.
  5. dave121
    23
    Maryland
    2018 Prius Prime
    Was ~5 miles shy on EV R/T tonight...guess it's the cold setting in. Thanks fo the suggestions...some HV on the highway might be the better option to get me from our rural area to the stop and go thats 15 minutes from us.
    Thanks - Dave
  6. bisco
    49,521
    sounds like a good plan
  7. KP7
    KP7 Member
    50
    42
    New England
    2018 Prius Prime
    Welcome Dave. I've had my prime for a few months now and here's what I do daily (90 mile round trip): turn on the ICE to warm it up and crank the cabin heat while it is on, then go EV to the highway and hv on the highway. I then use up all ev charge on the way home when it is a bit warmer. In the summer I'll use ev in the morning when it is milder.
    The first approach will likely work well for you in the winter and I'd guess that you'll be able to make a round trip in ev in the summer.
    jerrymildred likes this.
  8. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    If you really want to drive yourself crazy, determine your gas cost per mile at 70mph and cost on EV. Depending on your electric rate, and cost of gasoline, it might be less expensive to burn gas at 70mph. In my area, electricity would still be less expensive than gasoline, so I might flip over to Hybrid for 5ish highway miles and plan to arrive back home just as I run out of battery. Probably not worth the hassle and wear & tear on the push buttons .
    Tideland Prius likes this.
  9. dave121
    23
    Maryland
    2018 Prius Prime
    Thanks, seems this is working out best for the cold. I realize I probably won’t reap the full benefits of those with shorter, more stop / go drives, but any way I look at it, my current mpg is a major improvement over previous cars. Lovin’ this thing more and more every day.
