Compatible Alloy Wheels-Rims (silver vs black) Gen 3 Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by StephenFromCT, Jan 19, 2022.
  1. StephenFromCT
    StephenFromCT Junior Member
    Connecticut
    Hello all,
    I have a question about alloy wheel rims for a Gen 3 Prius "hybrid" (not V, not compact, not plug-in).
    I want to buy a set of used wheels rims to mount snow tires.
    The early (2010-2012?) Gen 3 Prius came with "five spoke" SILVER alloy rims (42611-47101, formerly 42611-47100).
    The later (2013-2015?) Gen 3 Prius came with "five spoke" BLACK alloy rims (42611-47270).
    Can I mount snow tires on silver alloy rims (from an early Gen 3 car) and mount them on a 2013 Gen 3 car?
    The silver wheels-rims are both less expensive and easier to find (in used condition).
    Yes, I read on this site that the black wheels-rims may have improved manufacturing specifications (and safety specifications). I plan to use the tires only during the snowy months.
    I am not worried about the cosmetic difference (which is less obvious with the wheel covers which cover the spokes).
    Thanks for your ideas!
    Stephen
  2. Mendel Leisk
    38,726
    I think they're 100% compatible. The centre caps should be swappable as well.
    Merkey likes this.
  3. Merkey
    Merkey Active Member
    259
    236
    Birmingham, Michigan
    I like the black rim with 5 spoke wheel cover of the 2012-2015 years over the 2010-2011 years with the silver wheel and different cover. However, if the wheel cover is not used, the silver looks better. Toyota has gotten a lot of use out of that alloy wheel design over the years.
  4. Mendel Leisk
    38,726
    4th gen 15" rims are also compatible, except they require a different centre cap: there's a groove inside the central bore for the centre cap jaws, and it's been shifted.
    Merkey likes this.
  5. PosauneGuy
    PosauneGuy Member
    117
    88
    California, here I come...
    I have both a 2011 and 2015 Prius. The silver and black rims are completely interchangeable. I have snow tires on both silver and black rims and they work fine on either car.
    Merkey likes this.
  6. Mendel Leisk
    38,726
    If steel rims are being considered, these are 100% compatible too (hub opening an exact fit), what I'm using:
    Corolla 15" black steel rims p/n: 42611-02471
    With lug nuts p/n: 90942-01007 (utilitarian, open-ended, galvanized)
    Merkey likes this.
  7. Tombukt2
    Tombukt2 Senior Member
    9,134
    1,586
    Durham NC
    Same on persona but 17 alloys factory. 1 set of styled steelies 205/50-17 all weather. The 15 all swap steel and alloy
