Complete power blackout after pressing power button to turn off car
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by electrontechnik, May 24, 2016.
  1. electrontechnik
    117
    31
    Video says it best, but here's a description:
    2010 Prius, ~250k miles, pressing power button to turn off on results in a semi-regular "pulling the plug experience" instead of a graceful shutdown displaying the mileage and time, can happen a couple times in a day. IGCT relay and both integrated relays replaced in the fusebox, as well as power switch. Takes between 2-90 seconds to recover and turn back on. Is lights out and dark during that period. No codes shown in Techstream. Sometimes is bad enough that (as caught in the video), the Nav system reloads the DVD and settings as you see in the video. However, bluetooth and all other functions work once it's up and running. HV battery replaced last year, as well as 12V battery.
    #1 electrontechnik, May 24, 2016
  2. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Looks like it's losing power.
    I would have the 12V battery tested. I know it was replaced last year, but s#€t happens.
    Also check terminal connections/cable conditions.
    Zizi and bisco like this.
  3. mrbigh
    3,686
    699
    Long Island, NY
    I'm tempting to contribute a troubleshooting; if the battery terminals are in OK shape, check the negative side cable that connects to the chassis/body side for proper connection fitment.
  4. electrontechnik
    117
    31
    Sure enough, 12V hot end wasn't completely tight, must have loosened up since collision shop worked on it. Tightened it up and seems better so far. also stopped by the battery shop where I bought the 12v battery and they said it was still showing 520 CCA.
    Zizi, Jimi1976 and Mendel Leisk like this.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Surely you are glad that the problem you where facing had such a simple solution.
  6. Jimi1976
    242
    124
    Denver, CO
    There ya go!
  7. bisco
    51,994
    thank you.
  8. electrontechnik
    117
    31
    Absolutely! Im glad I picked up ~$200 of relays for $40 for spares considering I'm planning on putting another 100k on the car.
