Completed Fuel Economy Questionnaire
Discussion in 'Gen 2 Prius Fuel Economy' started by jharper03, Jul 7, 2014.
  1. jharper03
    jharper03 New Member
    23
    Omaha, NE
    I hope this is where I am suppose to post this questionnaire. If not, I do apologize. I filled this out because I just assumed I would have had a little better gas mileage. I know that since I just started driving a Prius it wouldnt be perfect. I am also very concerned that my fuelly mpg is so far off from my trip computer.
    Thank you all in advance.
    Josh
    - Have you read This Thead Yet?
    Yes
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    I am using Fuelly and my first reading was 36.5 mpg but my trip computer in my Prius said I should have had around 49.6. Is the computer reading really that far off? Is there a way to calibrate it?
    - What fuel economy are you expecting and why?
    I was hoping to get around 45 mpg
    - What are the approximate outside air temps?
    87, 85, 92, 95, 90, 95, 97
    - How long are your trips?
    usually around 12 miles one way.
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    I am about 50/50 split. It is all city but I drive the highway through town where I average 50 mph for 8 miles of the trip. Some times I take a non highway route but there are more hills that way.
    - What region/state are you in? (if you haven't set your location in your profile)
    Omaha, NE
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    gentle hills mosty with some steep hills. Not flat at all.
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    No, dead on.
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    I checked my 12v and it read 11.2
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    Alignment good. no pull are abnormal tire wear. Tires are new.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    I dont know but I do have the touring wheels on it.
    - What are your tire pressures?
    I dont know
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    2004 Chevy Malibu, auto 2.2 L 4 cylinder. I averaged 23 mpg
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I am trying to do the P & G most of the time but I believe since my speeds are over 41 mph I am not able to get the arrows to go away. It always shows arrows from the gas motor but still displays 99.9 mpg.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    I let it warm up for a about 30 seconds every time.
    - Are you driving using D or B mode?
    D
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    AC every time. I read that I need to keep the AC on to keep the battery cool. I keep it on LO with the fan on first setting
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    This is my first week driving the Prius and my first reading.
  2. usnavystgc
    3,159
    989
    Tucson, AZ
    You can't go by just one fuel up. I have never found that much of a disparity from the gauge mpg to actual. I think 3 mpgs is the biggest disparity I've ever seen. Here's a couple things for you though.
    1) What is the psi on your tires? Air them up to 2 psi below max sidewall
    2) You say you keep the AC fan on low but, what's the temp set at? If the temp is at max low, the compressor will work all the time causing excessive drain on the HV battery and in turn affecting your fuel economy. I recommend setting it on AC auto and setting the temp to 78 or so. I find this a reasonable compromise temp (not too hot, not too taxing on the compressor).
    3) When you get up to cruising speed, do you take your time or do you go straight to the speed and hold? The latter is better
    4) You need to make sure the car is in S4 (read attachment). If its in any other mode, you will not get the best fuel economy.
    5) You also appear to have the Touring model which is known to get less fuel economy than the standard model (but only by about 3mpgs).
    jharper03 likes this.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    You have a North American Gen 2, which included a flexible bladder to reduce vaporization of the fuel. The flexibility of this bladder varies wildly. In MS I had fill ups between 8 and 11 gallons, but folks from near Canada have reported much smaller fillups yet. This variability will not impact fuelly over enough time, but plays heck with single tank results. (I found the onboard MPG to only be about 1% over fuelly over time)
    I will give you my Gen 2 fill up mantra:
    If your Mother in Law is in the car, get gas at 3 pips, she will never quit telling EVERYONE how you stranded her.
    If your spouse is in the car, get gas at 2 pips, they will never let YOU live it down.
    If you are alone, you can get gas at one pip, walking to gas station builds character. (Gen2 needs 3 gallons before you even try to restart)
    If the last pip ever starts blinking, get gas NOW. I had it run dry in 7 miles. (I also had it NOT run dry in 30. You just can't tell)
    Do not try to drive on just battery power.
  4. jharper03
    23
    Omaha, NE
    Thank you all for the replies. Much appreciated.
    I just took a look at my tires (which are new, on them when I bought the car last week) and they are Fusion Touring 195/55R16. Fuzion Touring (H- or V-Speed Rated) I am assuming that those are not helping my MPG right?
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    11.2 volts is way low for a 12 volt battery, you should plan on replacing it soon. In some failure modes, the 12 battery can be a significant MPG drain.
  6. jharper03
    23
    Omaha, NE
    Where has others found to be the best place to purchase the 12v?
  7. bisco
    49,500
    if your computer is reading 49.6, you're getting at least 45 and probably a little more. follow some of the above advice and you'll be over 50. all the best!(y)
  8. bisco
    49,500
    optima is a good one. so is the oem from the dealer. exide makes one, check with local retailers like pep boys and auto zone. and get some good low rolling resistance tyres like michelin energy.
  9. bisco
    49,500
    how many miles on betsy?
  10. jharper03
    23
    Omaha, NE
    Thanks for the info. She has 115K
  11. fuzzy1
    10,171
    Did you fill it up yourself when you bought it, or did the seller just say it was filled? If the later, then you don't really know if it was truly filled up, so don't count any miles before you personally filled it.
    Please find out. Underinflation will cause significant MPG loss, though shouldn't explain your entire shortfall.
  12. jharper03
    23
    Omaha, NE
    Yes I did fill it up my self. I made sure to let the bladder breathe :) Just sounds weird...... and I need to stop and buy a tire gauge.....forgot to take my old one out of the trade in vehicle.
    Thank you for your reply
  13. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Greetings jharper03,
    Like others said, pump the tires up. Try to run them at the maximum pressure stamped on the sidewall. Make certain the front tires have two pounds more than the back tires. If the ride is too rough, drop the pressure in two pound increments until you are comfortable. Set the A/C at 76 or 78 AUTO, NOT on LOW and fan speed low. If you are in a real hot area, 74 might be more comfortable when the sun is blazing. LO Setting, that alone is really dragging down the MPG (the A/C that is) as the compressor is running full speed at all times. Runs on electricity which is generated by the ICE and regeneration from braking. Use a good solar shade on the windshield when you are parked. Will help to keep cabin cooler, which in turn will make A/C work better with less energy. Make sure the tires are LRR (Low Rolling Resistance). If they are not, when the tires are worn out, get good LRR type tires. Your short trips are not helping you. As other's stated, Touring model's get about 3 MPG less than non touring. That 12 volt battery is toast. Get a new one. I recommend the one Toyota sells. Follow the instructions in the link in my signature below to change the battery. Dealer charges about $200 for the battery and anywhere from $75 to $150 to change the battery. You can DIY in one hour or less with a small handful of tools. Bladder has already been mentioned. You have to go by several tanks in order to get a real average on the Prius. When you see crazy numbers like you did, the next tank will probably be reversed in numbers and then it should settle down for a few tanks. That is the bladder for you. Saw the same thing on our Gen II. Learned real fast one tank figures don't cut it. Keep venting like you are doing, and fill at the slowest rate. DO NOT top off. Try to use high tier gas (Shell, Mobil, Texaco, Exxon, etc.) 87 octane is all you need. If you are not running synthetic oil, you should consider it. I recommend Mobil 1 5W30 for your Gen II. Keep an eye on the oil level. Check regularly. Lots of stories here on PC about older Pri using oil. Once it gets below the bottom dot, you will damage the ICE. Top dot to bottom dot is 1.6 quarts. At 3.9 quart oil capacity, at bottom dot you have less than 2.5 quarts in the ICE. So, like I said CHECK THE OIL REGULARLY. Make sure the air filter is clean and that the throttle body is clean also. Check and or replace the Cabin Filter also. Will help the A/C to work better. (Less Energy Again) Check both coolant loops. If one is low, top off and bleed air if necessary from the loop. Use only Toyota SLLC in the coolant loops. You might consider trying to determine if the spark plugs were ever changed, and if the coolant was drained at 100K. If not, both items should be done. I know I covered more bases than just the normal stuff that pertains to the questionnaire but you may have other issues that need to be addressed.
    On the 12 volt battery. Be aware that the battery is a AGM type battery with special JIS posts. It is also equipped with a vent tube. Use the correct battery when replacing. You won't find this battery at WalMart. A fully charged AGM type battery should measure 12.9 to 13.1 volts with NO load.
    Please update your profile with your location. It helps when answering questions about your Prius. Especially if you are in the UK or elsewhere. Different regions of the world have different stuff on the Prius. It does affect how the answers should be in certain questions.
    Finally welcome to Prius Chat. There is a wealth of information here and some great folks that are ready to help you get the best out of your new to you Prius. Congrats on buying the best hybrid out there in my opinion.
    Peace,
    Ron (dorunron)
  14. jharper03
    23
    Omaha, NE
    Thank you all again for your advice. I have had my Prius for a week and love it. Just filled up again and my MPGs went up to 51.4 so I am pleased. I understand now that it will fluctuate up and down but I still can not believe that I own a car that gets that well of gas mileage :)
    Data Daedalus and usnavystgc like this.
  15. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Yeah, just keep plotting the tank fill calculated MPG in Fuelly. You'll probably see the graph bounce up and down a lot (due to the inconsistency of the fill volumes), but after a while the trend line will be clear, and will give you a very good estimate of your true MPG.
    BTW. Over a single tank, the computer displayed MPG is usually more accurate than a manual "gas pump" calculation. Over time however, the plotted trend line will give you the most accurate figure.
