Comprehensive Prime MPG Data Spreadsheet
Discussion in 'Prime Main Forum (2017-2022)' started by O Haiii, Dec 31, 2019.
  1. O Haiii
    O Haiii New Member
    Socal
    Hey guys,
    I recently filled up my prime for the first time and would like to keep some good solid data on the different aspects of the Prime's mpg. Would you consider this spreadsheet a pretty comprehensive approach? Any fields I'm missing or you guys would add? Thanks!
  2. 2wheelsandopenroad
    2wheelsandopenroad Junior Member
    Montreal,QC
    2019 Prius Prime
    I use Fuelly, much more convenient to add the fill up info.right after visiting the gas station....which is not that often :)
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,963
    New England
    It looks as comprehensive as it can be. However, with a PRIME if you charge often and drive on EV mode, MPG displayed and calculated by gas usage is basically a useless information. As shown by other PRIME drivers on this forum, you can go thousands of miles on EV mode not using any gas, resulting in very high mpg. In the spreadsheet you posted, you have a data column titled "miles charged on plug". How are to going to keep recording this number? Unfortunately, Prime does not show direct data for this number anywhere.
