Compression Test
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by janders, Jan 23, 2010.
  1. janders
    janders Junior Member
    23
    SF Bay Area
    I just bought my first Prius, a 2006 with package #7. I would like to check the compression ratio on the ICE and wondering what the procedures are or if anybody has done one. Any help would be appreciated.
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    The procedure for checking the compression requires the Toyota Scan Tool so that you can put the Prius into "Inspection Mode" and then choose the menu item: DIAGNOSIS / ENHANCED OBD II / HV ECU / ACTIVE TEST / CRANKING RQST.
    I believe it is possible to put the Prius in Inspection Mode without the scan tool, but I don't think it is possible to command the Cranking Rqst without the scan tool.
    If you have access to a Leakdown tester, you might be able to run a Leakdown test instead of a Compression test. I believe you could do the leakdown test without any proprietary scan tool, but I haven't tried (and haven't had a reason to).
  3. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    you're right. maintenance mode is easy.. anything else requires a tool.
  4. janders
    23
    SF Bay Area
    Thanks for the advice. By the time you responded, I had already done the test. I probably didn't do it correctly because all I did was remove all of the sparkplugs and hook up the compression gauge up to one cylinder at a time, turned the engine over and recorded the reading. I got 135-150 psi over all cylinders. That is lower than the 13.5 compression ratio, but I was more concerned about the consistency from one cylinder to the others.
    I don't think I did any harm to the engine because I'm getting 45 mpg after the test and the engine sounds and feels normal. Any comments?
  5. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    Because of the Atkinson cycle that is used (after induction about 1/3 of the inlet charge is pushed back out again) the compression ratio is effectively about 9:1.
    kevin
  6. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    The pressure you saw is about right for the above effective compression ratio. Note that the engine is spun faster than in a "normal" car.
    No, you wouldn't do any damage to the car doing the test the way you did. Nice bypass of all the computer systems! You -could- get the computer all upset doing what you did as the expected engine start didn't occur, but I guess if you shut it off after a few seconds (the time it takes for a compression reading) it doesn't enter a code.
  7. Patrick Wong
    18,200
    6,471
    I'm sure you didn't do any harm. However I don't know what to make of your pressure readings, since a normal engine will be spinning at ~300 rpm via the starter motor while the Prius engine was probably spinning at 1K+ rpm via MG1.
    You are right that the main concern is that the readings should be relatively constant.
  8. Raqune
    Raqune Junior Member
    28
    Portland Oregon
    You said, "turned the engine over...", but didn't say how. It seems everyone else understood what you meant but me - guess I'm kinda' slow. Did you just go to READY mode and wait for engine to try starting then shut it down as soon as it started to crank?
  9. Glenn Blanc
    Glenn Blanc New Member
    I did the same thing, I removed all the spark plugs, unplugged all the ignition coils/igniters so there would be no spark and attached the vacuum gage to the first spark plug hole. I then turned the car on to ready (brake on, power button) and waited until I heard the ICE turn over (the MFD also indicated ICE operation) and quickly hit the power button to shut it down. I repeated the process with the other 3 cylinders. With only a few seconds of operation all 4 cylinders read 135 lbs. Just to make sure that was the maximum reading (I agree with the other poster who said the absolute reading is not as critical as any differential in the readings) I let it crank for 4-6 second, at that point the engine shut down on its own, turned on the check engine light, the red triangle and the ! on the MFD. I looked at it with my iPhone Engine Link app and it showed 4 seemingly random diagnostic codes:
    P0403 - Exhaust Gas Recirculation Circuit Malfunction
    C1103 - ABS Hydraulic Brake Switch Circuit Failure
    C1203 - Engine Control System Communication Circuit Malfunction
    C1303 - Right Front Isolation Clamping Circuit Failure
    I then checked it with PriusDash on my laptop and saw the codes I would have expected:
    P0351 - Ignition Coil 'A' Primary/secondary Circuit
    P0352 - Ignition Coil 'B' Primary/secondary Circuit
    P0353 - Ignition Coil 'C' Primary/secondary Circuit
    P0354 - Ignition Coil 'D' Primary/secondary Circuit
    I cleared the codes using Engine Link (not sure how to do it from PriusDash) and all is well.
    I was checking the compression because I had the spark plugs out anyway to replace them. I have a 2005 with 114,000 miles that I just purchased and I recently put new NGK IFR5T11 Laser Iridium plugs (gapped to .044), cleaned the MAS (Mass Airflow Sensor) and the throttle body thinking it was all nearly due. Shortly thereafter my mileage which was in the high 40's started to sink and after a few weeks was down in the low 30's. Since I had a spare set of plugs that I was going to put in the 2004 Prius I decided to swap them out to try to isolate the problem. The old ones looked fine but sure enough the new ones brought the mileage up into the high 40's, a little better than before I started.
  10. eth2oski
    eth2oski Junior Member
    Northern California
    I've got 293,000+ miles on my '05 Prius. Just had it checked 125-129, all four, as I was replacing the plugs (after 160k). The only "repairs" in nearly 300k miles: replaced both water pumps, one twice, and an idler pulley (with that mileage these could be deemed "maintenance," not repair). Other than regular maintenance that's it. Most unbelievably reliable and least cost to operate car on the planet; and it's comfortable and safe! Lifetime average MPG 47.9.
  11. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    does anybody know what the compression should be? if you are using a conventional over the counter Napa discount bin compression tester you compression test will read lower than it actually is. it would not cost very much to take it to Toyota and get them to use a high quality compression tester to do the test properly.
  12. Bens04Prius
    Bens04Prius Junior Member
    New Jersey
    I did a compression test & got 90-97 between all 4 cylinders - I have 272K miles, but I'm assuming that since the numbers were basically the same between all 4 cylinders that the engine is fine - this is especially since I felt like i couldn't tighten the tester in the cylinder - it would just keep turning forever...
  13. Patrick Wong
    18,200
    6,471
    I would not say your engine is "fine". At best you could say that the cylinders show even wear. However that wear may exceed spec.
  14. Bens04Prius
    New Jersey
    Patrick,
    What are the consequences of exceeding spec?
  15. Patrick Wong
    18,200
    6,471
    The engine operates less efficiently and produces less power than when new.
  16. ChapmanF
    15,433
    I've never known a compression tester to do that, unless perhaps it came with multiple ends and you were using one with a different (but similar) thread to what the Prius plugs use? Anyway, if it couldn't be tightened down, I don't think I'd consider the readings to be worth much.
    -Chap
  17. Bens04Prius
    New Jersey
    So I just double checked - it did come with an adapter which I assumed was for bigger holes, but now I see its about the same size but the threading may be a tiny bit tighter. Either way, it wasn't like I was able to just pull the hose out of the cylinder - i did have to turn it counterclockwise to get it back out and when I disconnected the guage from the hose it did release a whoosh. I suspect that the reason it didn't tighten is because the hose would turn around the metal bottom part that would get threaded into cylinder - once it reached a certain tightness it wouldn't turn the hose & metal together but only the hose.
  18. ChapmanF
    15,433
    Hmm, still seems weird to me, but if you think it was tight, then the question is back to why 90 to 97. What was the throttle position while you cranked? Most manufacturer instructions I've seen for compression testing instruct to have the throttle clamped full open. I'm sure if you were using Techstream to command the test, the throttle motor would just handle that for you.
    Good point; OTC 5609 is one example of a leakdown tester. To use it, you need an air compressor, but it's another way to get the same info, without needing a VCI to make the engine crank. I like it, it seems more civilized, you're not trying to watch the compression needle pump up and decide how long to keep cranking. You just block the crankshaft from turning, open the air valve and read the numbers. It's quiet, and if there's leakage, you can actually hear whether it's going into the head or the crankcase or one of the manifolds or the water jacket. Kind of neat.
    You do need to put a socket and handle on the crank bolt and secure it somehow, or the compressed air will flip it around.
    -Chap
  19. Bens04Prius
    New Jersey
    Chap,
    I was actually thinking about this this morning and I realized that maybe the reason is because I did the test on the car first thing in the morning before warming the engine to operating temperature. It was a pretty warm day (already about 75 degrees when I did it) but the reason I didn't warm it up was because I wasn't sure how warm I should really get it, and I was primarily concerned with getting consistent number between cylinders - I was under the impression that without the techstream it wouldn't be accurate anyway...
    Again, my primary concern was to eliminate the possibility that one of the cylinders was bad and causing a misfire so I could focus on other troubleshooting steps (like buying expensive coils). Since sparkplugs are so cheap it might make sense to just swap out all 4 and do the compression test again after reaching operating temperature before I put in the new plugs. As per my post here: Misfiring or something else? | PriusChat no one has yet commented on the condition of my plugs. What are your thoughts?
    Thanks!
