Computer upgrade trouble
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by danmiller3, Jul 26, 2004.
  1. danmiller3
    danmiller3 Junior Member
    37
    Larkspur, CA
    Hi folks -
    Sorry if this has been discussed elsewhere. If there is a thread someone can point me to, that's great.
    I had the recall upgrade done on my Prius a few weeks ago. Ever since then the car seems to be struggling. The gas mileage is down from 46.1 on average to less than 43 under the same driving conditions. It seems to not like electric mode nearly as much as it used to and just seems to be driving rougher.
    Is this possible, or all in my head?
    Thanks,
    --Dan
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Is it the same tank of gas, or did you fill up since the upgrade?
    I have odd drops in MPG occasionally. I drove to the oil change Saturday at 48MPG, and now I'm around 45MPG if I'm lucky. Don't know what's up, but I did add more of the X-1R lubricant in hopes it gets me back where I want to be...
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    There is no reason the SSC's should cause any change. There are a lot of possible causes. Did you have any other work done? Did they change your tire pressures? Have you checked just in case?
    Give it a tank or two of gas and then decide if there's any difference. I had an initial decline in mileage immediately after my update, but that was mostly b/c they'd drained my Traction Batt. during the update. I caught back up by the end of the tank.
    I strongly suspect factors other than the update being responsible.
  4. richard schumacher
    7,663
    1,038
    United States
    If this behaviour doesn't go away with a fresh tank of gas you should go to a dealer. If I understand posts by mdacmeis in other threads, the computer is completely re-programmed when any update is done (that is, all of the programming is re-loaded). If so, then it is possible that some part of it got corrupted. Error-correction codes and self-tests are not perfect.
    Again summarizing from other posts, it is crucial that the car have a charger supplying power to the 12V battery throughout the update (the 12V battery supplies power to the computer; during the update the engine will not start and so the car cannot recharge the 12V battery by itself), and that the update is allowed to complete without interruption. In other words diplomatically remind the service department that the Toyota procedure must be followed *exactly* with no shortcuts.
  5. jamarimutt
    jamarimutt New Member
    985
    Could you explain why this upgrade was needed?
  6. efusco
    19,891
    1,192
    Nixa, MO
    There have been 2 Special Service Campaigns, well covered in previous threads, the SSC-40a and SSC-40d. If you do a search you'll find all you need to know about those campaigns. In short, they had nothing to do with performance. the SSC-40a corrected a programming glitch that could, after getting DTC code (non-critical) prevent the Prius from restarting. The SSC-40d corrected an error that prevented some DTC codes from being read/recorded. That's about it.
  7. mboileau
    mboileau New Member
    278
    SF Bay Area
    FWIW, I've been fanatical about tracking my mileage and the various driving and weather conditions. Since the update, my mileage has dropped about 5 mpg consistently (3rd tank since). Now, it may simply be that the weather is getting warmer and warmer and having the A/C on Auto (as I always have had it) is having that affect, but I thought I'd mention it.
  8. efusco
    19,891
    1,192
    Nixa, MO
    I, too, am pretty fanatical....let's take a look at my numbers:
    3 Tanks Prior to SSC-40D:
    57.2, 58.1, 48.5 (a bit of an aberancy due to long interstate speed trip that tank)
    3 Tanks Since SSC-40D:
    56.1, 57.9, 55.7
    Other than the pre-SSC trip with the low mileage I'm getting VERY consistant mileage. Just thought I'd mention it! :wink:
  9. rflagg
    rflagg Member
    947
    Springfield, VA
    I highly suspect tire inflation to be the problem here, especially with repeated reports of the mechanics filling all tires to 32PSI instead of 2PSI's extra in the front, as mentioned on the driver side door.
    The first oil change I had, they deflated my tires from 42/40 to 32/32. Second one they didn't adjust them - unfortunately that was also when they rotate them, so it was then 40/42. Buy a $1 tire pressure gauge and check them, and at the very least up it to 38 front 36 rear.
    -m.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well let me shoot down the air conditioning theory. i am averaging 54.2 mpg in 100º heat for three days that we had that kind of weather (crossing fingers)
    one of you said you had your oil changed. have you checked to see if it was overfilled? that has been a problem for some here and overfilling will affect your mileage.
    as for tire pressure, i use a highly accurate digital gauge and my car came from the dealer at 38.5/36.5. when i took my car in for its 30 day checkup, i checked the air pressure of the tires since they mentioned checking the pressure and the pressure was 38.2/36 so apparently 38/36 is the new standard.
    i had my update too early to tell as it was done in the middle of my 2nd tank of gas. and as far as going into EV mode, my car never really did EV that much. people talk of taking off from a stoplight in EV mode, well ive tried it several times and i cant seem to do it. i even tried accelerating up to 25 mph, engaging the cruise control and trying to bump up to 40 mph and that didnt work either.
    but to be honest with ya, im not that hung up on running in EV mode since the battery only has the charge to run the car for only a few miles at best anyway so i dont see the point to forcing EV mode unless you are just moving your car from one spot to another for washing or cleaning or something.
    as it is, the ICE runs so intermittently at low speeds that its not a concern for me. when i first got the car, my freeway mileage was way better than my city driving but now things are starting to even out.
    my freeway driving is averaging just over 2 mpg above EPA, i wish i could do that on city driving. that would be nice. but i will say my city driving has gone from about 48 to nearly 53 as far as i can tell ( i do mostly city but mix in several freeway stints) and its still rising.
    i know its the wrong thread, but my mileage right now is
    tank # 7 383 [email protected] mpg
    overall MPG (last tank not included)computer 52.3 by fillup 51.9 over 2943.7 miles
  11. jamarimutt
    985
    I have not received from my dealer or from Toyota a notice about the need for a comouter upgrade. Until I do, I'm following the don't fix it if it ain't brokenlaw.
    I have found that frequent use of the air conditioner reduces mpgs (50 to 48). Lower tire pressure has the same effect; I'm currently using 38/36.
  12. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    Computer upgrade
    I had the 40D work done last week. They also rotated the tires and followed my instructions about tire pressure. They were going to upgrade the Nav but they don't yet have the CD from California. I had 2nd oil change with synthetic 5-40 and what a shock this time. Charge was $8.53 per quart for the Castrol.
    I'm now going to price the oil at other locations to see what the price really is. May buy somewhere else and take it with me for oil changes.
  13. mboileau
    mboileau New Member
    278
    SF Bay Area
    My tire pressure has been consistent, and set to 38/36 as others have. Although I do have an accurate digital pressure gauge, I've found it really handy to have the pressure calibrated stem caps. I ordered a set of 4 from garage-toys.com for about $12 and they're great. The end of each stem cap is color-coded based on measured pressure. They're green when properly inflated, then they change to yellow and eventually red as pressure is lost. Takes 2 seconds to glance at all 4 wheels every now and then to be sure they're still OK. I love no-brainers.
  14. mikepaul
    1,763
    Columbia, SC
  15. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I'd check Truck Stop Shops to see what they have.
  16. mikepaul
    1,763
    Columbia, SC
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i heard that those tire pressure stem caps were not very reliable. and i dont mind checking the tire pressure. i only do it once a week or so and i have yet to see any tire pressure change.
  18. mboileau
    mboileau New Member
    278
    SF Bay Area
    Well, for me they were less than $20 delivered, so it's not a big investment if they don't work out. When you order them from garage-toys.com, you have to specify what pressure you want them set to. They're supposed to maintain their accuracy to 2 psi. Since I wanted 38/36, going up to 40ish seemed plenty. I still have my handy digital pressure gauge, so I'll check it manually from time to time and let you know if there's a discrepancy.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    within 2 PSI???
    hmmm....
  20. ericst
    ericst Junior Member
    Waverly, NY
    Was this problem ever resolved?
    I just had my SSC-40D done a few weeks ago, and have been experiencing the exact same behavior! Very puzzling...
