Computers, cellphones and other eletronics drain key fob battery if they're close together?
Discussion in 'Gen 4 Prius Audio and Electronics' started by TheChosenOne, Mar 4, 2016.
  1. TheChosenOne
    TheChosenOne Member
    105
    36
    Cali
    Four Touring
    I think I read this in the manual. Is it as bad as it seems? How far should our key fob and electronics be from each other? Is it easy to change the battery or would we need to go to dealer for that?
    ETP likes this.
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Your Fob battery should be a CR1632, which is under $5 at any jeweler. (under $2.50 on Amazon)
    Plan on replacing it every 3 years.
    Your Fob uses radio waves to communicate with the car but is not all that bright, and may try to communicate with other wireless devices.
    #2 JimboPalmer, Mar 4, 2016
    ETP likes this.
  3. KenzoTH
    KenzoTH Member
    70
    38
    Rhode Island
    FYI: That battery (CR 1632) is also commonly available at drugstores CVS and RiteAid, many supermarkets and most bicycle shops as it is a battery used by many cycling computers and heart-rate monitors.
    ETP likes this.
  4. TheChosenOne
    TheChosenOne Member
    105
    36
    Cali
    Four Touring
    How do we change the battery though? Looking from the outside, I can't see a way to open it.
    ETP likes this.
  5. Pantelis
    Pantelis Junior Member
    Greece
    Hello!
    I found this but unfortunately it's for 2 Gen... Sorry...
    #5 Pantelis, Mar 7, 2016
    PriUncut and ETP like this.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  7. bisco
    49,489
    is this gen 4? fob looks a little different.
    o/p, i would keep the fobs at least 15 feet from the car when not in use, but you should check your manual for specifics, who knows what might have changed. i have my phones a few feet from the fobs with no problems, but very once in a while, someone will have battery draining issues for no known reason.
    ETP and TheChosenOne like this.
  8. SUPERCOOLMAN
    SUPERCOOLMAN Junior Member
    92
    Santa Clara
    it may not be battery draining issue. I have it happened a couple times over the last couple years when placing fob right next to phone with bluetooth enabled. I stopped replacing battery on the fob and it has been working just fine for over 2 year now
    ETP likes this.
  9. Geo13647
    Geo13647 Junior Member
    38
    Scotland
    I usually keep my phone & fob close together, not had any issues with it in 3 yrs, mr T usually charges about 4-5 times the price of the batt, so as previous poster said, easy enough to change yourself every 3 yrs. I notice that when the cars are in for a service etc, the keys are usually kept between the wipers, this seems to be a dead spot for the internal antennas. When washing the car I usually keep the fob about a metre or so in front of the car. Works for me, but easy enough to test.
    ETP likes this.
  10. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    I found the owner's manual has the instructions on page 628. (Prius 3)
    ETP likes this.
  11. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    #11 ETP, May 21, 2016
  12. HamiltonPrius
    HamiltonPrius Member
    107
    64
    Parts unknown (in the USA)
    To help save battery life you can turn the Fob off.
  13. bisco
    49,489
    cool! is there a switch on the 2016 fob?
  14. HamiltonPrius
    107
    64
    Press the door open button twice while holding the door close button
