Condensation and water build up in oem fog lights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yumseyo, Sep 20, 2017.
  1. yumseyo
    yumseyo Junior Member
    I have a 2013 prius level 5 with oem fog lights. I am getting condensation in both lights. I just installed some led bulbs and thought it was the o ring seal, so I took the o ring seals off the original bulbs and reinstalled the led s. Has anyone had this problem? I am probably going to purchase a couple of nokya bright yellow halogen s to see if the same problem occurs. Thanks in advance...
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Do you go through automatic car washes or something? Or drive through deep puddles with the foglights submerged? Condensation or water in the housing isn't normal.
  3. yumseyo
    No, I don't go thru car washes, nor puddles. There shouldn't be condensation in any lights right?
