Confirm 9.5 gallon capacity?
Discussion in 'Prius c Fuel Economy' started by garm, Feb 2, 2014.
  1. garm
    garm mpg + cool = win
    215
    Did I really have .002 gallons left? I didn't top it off! :eek:
    tk1971 likes this.
    49,446
    yikes! how many miles did you go?
  3. garm
    215
    ^ I don't keep track. I figured I had more when the last bar starts blinking though! I'll have to be a little more careful. o_O
  4. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    Japanese fuel tanks start life as metric i.e.36 L, which is 9.5102 gallons, so you had a bigger margin than you thought! :)
    garm likes this.
  5. Shibby
    Shibby Member
    78
    43
    Hagerstown, MD
    Most I've squeezed in was 10.05.
  6. Mo G
    Mo G Member
    317
    98
    Dallas,Tx
    ^^^^ you are pushing the limit. I like it. Most I done was 9.5.
  7. Snowball
    Snowball Junior Member
    48
    Southern CA
    Have you used this pump before? Could be a faulty pump? I just filled up this weekend and the pump said I put in almost 9 gallons, and when I manually calculated the MPG, it said I only got 48 MPG ( I have never gotten this low mileage). My scangauge and trip meter calculation was 57-60 MPG. It was a pump I don't use regularly and I think it was faulty.
  8. garm
    215
    I've used the pump before, but I don't track my mileage. (probably would be depressing given my "spirited" driving habits).
    hieronymous - thanks, that's really cool info
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Did you go past the first click? That's the major measuring point for the fuel tanks. The C will let you put in almost another gallon after the first click. I've seen 10.4 on some people's fuelly accounts before.
  10. garm
    215
    nope that was at the first click. That's what I meant about not "topping it off". :)
  11. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Cool, some people consider topping off to be when fuel is spilling out. Other people consider topping off to be the second click.
  12. garm
    215
    ^ I didn't know!
    ztanos likes this.
  13. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    i've run close to empty before and i got 9.8 or so.. and have seen friends fill up 9.6-9.7 gallons before the pump clicked.
    so i'm wary about the 9.5 gallon capacity rating. granted you should never run that close to empty in the first place, but stuff happens.
  14. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And you also should NEVER go beyond the second click.......because overfilling can damage the vapor recovery system, resulting in an expensive repair.
  15. garm
    215
    ^ Have you had that happen to one of your cars before?
  16. Easy Rider
    982
    210
    N. Central Florida
    NO.
    Because I visit forums like this to learn from the mistakes that others make.
    And to relate the mistakes I make to try and help others.
    That is one that I learned from others; not one that I did personally.
  17. garm
    215
    Kinda sounds like I offended you somehow. I'm just curious, I've read about this and never met anyone who experienced damage to their vehicle. That's why I asked.
    I can see how fuel might possibly leak down the evap line to the charcoal cannister.
  18. Easy Rider
    982
    210
    N. Central Florida
    That's exactly what happens and once the canister is full of gas, there is no way to "fix" it short of replacement.
    Since you really aren't gaining anything by doing it in the first place, I don't understand why people do it at all.
    And sorry for the attitude. I've run across FAR too many people who think the only to know about anything is to experience it first hand.
  19. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I've been reading about this so-called canister failure and in the 20 years of working on cars, I have only ever heard of 1 canister ever failing... fyi... it had nothing to do with over-filling the gas tank.
    In my experience the reason I did it in my old car was because it had a tank mileage range of 350 miles. If I didn't fill up the tank to the brim and only stopped at the first click I would only get 300 miles max. I filled that up ever 3 days vs every 4 days. Over time that adds up. That car went 180,000 miles and never had any issues with the fuel systems.
  20. Easy Rider
    982
    210
    N. Central Florida
    Your mileage may vary.
    That can apply to a lot of things.
    Just because you have never seen it doesn't mean that it doesn't happen.
    And just because it happens to one person with a particular model vehicle doesn't mean that it will happen to all.
    Not many people put on the mileage that you do I suspect and for most getting in an extra gallon of gas
    won't make a significant difference to anything.
    I don't think it is worth the risk.
