Confused about traction battery voltage.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Sep 7, 2019.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    Hey all.
    So I set up Torque pro so I can monitor my individual battery voltages. All 14 read 15.6 plus or minus .02. I’ve looked at some other voltage displays on other cars and seen anywhere from 16.3 - 17.5. Anyone know what’s going on? Bring me in he know folks. (2006 220k miles battery age unknown, average mile as over several tanks 44.3 mph)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    It’s just the voltage at the condition the pack is in. So if you were at a lower %charge on the pack, the lower the voltage would be;).
    If they are that close, that’s a good sign:).
    But performing a load test is a better way to know(y).
    Skibob likes this.
  3. Ianmeister
    316
    319
    Meridian Idaho
    I see
    I’ll try checking the numbers at different soc. Yes they were all very nearly identical. Thanks!
    Raytheeagle likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Eagle hit it pretty good.
    15.6 is a fairly normal voltage for a block that has not been exposed to a charge condition recently or even overnight. Remember, that's still 7.8 volts per module. The ones you see >16 have most likely recently been exposed to a charge current, or currently being charged. for instance, if you roll under battery power for the last quarter or half mile when getting home, you'll see lower voltages. I don't think you have anything to worry about.
    Ianmeister and Raytheeagle like this.
  5. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Sometimes the eagle does land:p.
  6. Ianmeister
    316
    319
    Meridian Idaho
    Ok. Cool. One thing I’ve noticed is that if I sit at a stoplight on a crazy hot day with the AC blasting the SOC drops to one purple forcing the engine to kick in after about 3 minutes. Is that normal?
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    The battery is weak and is close to failing. A quick cycling from full to empty is one of the first signs;).
    The load test with diagnostic readers will show you how bad it is, but it ain’t that great:cool:.
    I’d plan for either a replacement in the future, or reconditioning it if you like to DIY:).
    Good luck and keep us posted (y).
    Skibob likes this.
  8. Ianmeister
    316
    319
    Meridian Idaho
    Hmm. Sad face
  9. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    This is one of the great times for using the Hybrid Assistant/Hybrid Reporter apps with a bluetooth obd adapter. There's a HV battery test you can perform using the AC system. It will log and graph all 14 block voltages. It makes it very easy to see if all blocks are fairly well balanced or if there's weak blocks. A well balance battery will show all 14 graph lines in a tight group, very close to one another. Any weak module/block will fall out of that range much more quickly. It will be obvious.
    Just Another HV Battery Thread and Experiments | PriusChat
    Look at post 5...that graph is similar to what you may see. You can see one block that falls off a cliff about 5 minutes into the test.
    Ianmeister, Skibob and Raytheeagle like this.
