Confused by Catalytic Converters
Discussion in 'Gen 2 Prius Main Forum' started by Jeff Guy, Jul 16, 2021.
  1. Jeff Guy
    Jeff Guy New Member
    Boston
    I own two gen2 priuses, a 2005 and a 2006both bought when new, and both have over 200K miles, and both still running. I just replaced the main battery in one of them with a used battery from a junkyard and had the exhaust manifold replaced, so I plan on keeping them for a while yet. Both of them sometimes get a P0420 code, which I assume means that they both need new catalytic converters.
    I live in Massachusetts, which for some reason allows this code to be exempted, so I will still pass annual inspection even without replacing the cat units. But when looking up replacement cats I found what seems very bizarre to me. It looks like OEM cats sell on eBay for a thousand dollars or so, for scrap only. Yet brand new aftermarket cats, which presumably clear the 0420 code, are only one or two hundred dollars or so.
    Why are the OEM units worth so much in scrap but aftermarket ones nothing? Is there a different catalyst being used, or far far less of the same catalyst? Something else I’m too dense to imagine?
    Do the aftermarket units really work to scrub pollutants and prevent the 0420 code or do they somehow cheat the car’s pollution detectors and leave the pollutants un-scrubbed?
    Finally, why are Prius cats being targeted for theft? All cars have cat converters - is the same thing happening to other cars, with thieves cutting out and stealing the cats for scrap - or is there something unique about the Prius cats to make them worth more than other cars?
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,518
    Pacific Northwest, USA
    There's 2 grams each of Rhodium, Palladium and Platinum in these over-engieered Gen2 cats... Currently Rhodium sells for $694 a gram, Palladium $101 a gram and Platinum $40 a gram.
    Basically it's cheaper to get Rhodium from old Prius cats than it is to mine it...
    And new more modern cats don't require as much of these precious metals to do a similar, thought less thorough job.
    The good news is a precious metal dealer will pay you $1500 for each of your cats when you replace them unless a thief does that for you.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Go on youtube and look up
    Prius Stolen
    Cat theft is quite epidemic especially overseas.Lots of YT's about it. Not just Prius affected but its high on there list as the G2 used alot of precious metal in there cats.
  4. ETC(SS)
    6,555
    G2 Priuses are SULEVs (Super Ultra Low Emissions Vehicle)
    No.
    That's not me being snarky.....some supposedly sober, educated adult actually came up with that out west of the Rockies.
    G1's are "only" Ultra Low Emissions Vehicles....and they're mostly razor blades now.
    SO.....here's where it gets kinda interesting....
    G3 Priuses are ALSO Super Ultra Low Emissions Vehicles - but until recently their cats were not being jacked at nearly the same rate as the G2's.
    Also...the catnapping doesn't seem to be as proportionately high outside zip codes that begin with "90" which also happen to be places where you HAVE to use OEM catalytic converters to get your cars smogged.
    Also Also.....G2,3 & presumably 4 Priuses are NOT the only cars that are Super Ultra Low Emissions Vehicles..
    Super ultra-low emission vehicle - Wikipedia
    AND YET.....
    G2 Priuses are still the principle target for catnapping.
    So.....
    Are Priuses just easier to steal cats from?
    Are their cats loaded with more of these metals than other SULEV's - if so WHY?
    Is there a black market for no-questions asked $1,000 cats when there is a waiting list for $1500 OEM cats?
    Is the fact that many people out on the left coast subletting their garages a contributing factor?
    Crime rates?
    Your call.
    Me?
    I'm thinking it's probably "D" or "all of the above"
    YMMV
    #4 ETC(SS), Jul 16, 2021
    douglasjre likes this.
  5. Maysha
    Maysha New Member
    Orange County
    Hello people,
    sorry if I intervene with this question a bit out of context, but I was wondering if any of you knew if geico still covers for catalytic converters theft?
  6. ETC(SS)
    6,555
    Unless it’s specifically excluded in the mice-type it should be covered under your comprehensive policy.
    File fast!
    They’re not going to stay dumb forever.
    Pretty soon they are just going to start totaling out G2s for $1500 cats or not renewing their owners.
    Edit:
    You CAN usually drive your catnapped car while you are waiting (and waiting….and waiting) for a replacement. It will sound kinda interesting and you may want to check your o2 sensor leads but there are YouTube vids that address this.
    One usually cannot drive a G3, but as I indicated in a previous post there’s not yet as much of a demand for these cats.
    Good Luck!
    #6 ETC(SS), Jul 17, 2021
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    You CAN drive a G3 with a stolen cat, if the thief was a "professional" and did not cut the exhaust pre-heater coolant line.
    Even if the pre-heater coolant line was cut, you still CAN drive it, if you reconnect the coolant with a short section of 5/8" heater hose and a couple of clamps. Then, top off the engine coolant reservoir tank.
  8. ETC(SS)
    6,555
    .....hence the word...."usually."
    Most folks will just call for the skid truck when they see the puddle of coolant.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    3,470
    1,514
    NJ-USA
    The OE Prius converters have more precious metals in them as they have to be warranteed as functional for up to 150 thousand miles. Aftermarket replacement converters only have to be functional for up to 25 thousand miles. You can do the math.
    Yes, the Gen2 Prius is very "easy" to remove the the cat. Jack up a side, cordless saw to cut through one thin pipe, cut the oxygen sensor wires, cordless impact gun on two bolts at the manifold. Can be done in 1 to 2 minutes.
  10. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    Gen 3 cats are just as easy to steal. It's the same technique as for the Gen 2's. The trick is to avoid cutting the exhaust pre-heater lines.
  11. Jeff Guy
    Jeff Guy New Member
    Boston
    Ok, that’s starting to make some sense, thanks for the explanations. So then my next question for those of us who can install an aftermarket cat and don’t NEED an OEM replacement, is how well the aftermarket units work, and which of them are worth buying, and which are just complete junk? Do some fail in a month? Are the hundred dollar units as good as the three hundred dollar units, and if not, how do you know which ones are worth buying? Has anyone sorted through the quality of the aftermarket units and how do we know the difference?
  12. ETC(SS)
    6,555
    If your goal is to keep your car from spitting codes, then almost any catalytic will “work.”
    If your goal is to keep your vehicle as SULEV as it was when it was new, then you’re probably going to have to stick with the OEM replacement.
    Since thermal inversions are not much of a feature in Bastan weather patterns, and since your government seems to have adult leadership in this one very small area, MY personal opinion would be to go with the party ticket and make your car “clean enough” which would be to say….cleaner than 90-percent of all of its contemporaries.
    Your call.
    My principle concerns would be corrosion and your car’s oil consumption - which is probably the root cause of the 0420 codes.
    If you’re the DIY type there might also be a third option for you besides letting your cats age in place or sending them off to the scrappers.
    You can try cleaning them if you do not mind taking them off to do so.
    Most of the manufacturers and other “experts” will tell you that cleaning these units is not practical, and in places where catalytic converters are less than the price of good used car I would agree…..and yet…..there are many many products and procedures out there in the inter webs.
    Again….your call.
    Getting rid of the 420 code is worth the effort if only because it will allow you to see if something else starts going wrong with your car.
    Good Luck!
  13. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    The forum search feature currently works (this isn't always the case), best to search and study up on all things gen2 when you have time.
    Not sure if anyone else has posted their findings, but @TMR-JWAP started a thread that was quite helpful : OEM and Aftermarket Catalytic Converter emissions | PriusChat
  14. ChapmanF
    15,617
    We're looking here for a cat thief who is thoughtful enough to avoid cutting your coolant lines, but not thoughtful enough to quit being a cat thief.
  15. Georgina Rudkus
    3,173
    2,213
    Taylors, SC
    It would be readily apparent that the thief is more concerned about getting smelly sticky coolant all over him if herself while under the car, NOT the victim.
  16. Isaac Zachary
    Isaac Zachary Senior Member
    1,875
    886
    This:
    There actually have been reports of people putting on aftermarket catalyitic converters, taking it down to emissions testing and failing the test based on exhaust emission levels only. Of course the amount of information on this isn't enough to be completely conclusive. But common sense tells you that a catalytic converter with hundreds of dollars of precious metals must be better at doing it's job than one with just a couple dozen dolors worth of the stuff.
    This is an important point. What caused the catalytic converter to foul up in the first place? It would be a shame to put on a brand new OEM catalytic converter and in a year or 6 months have it fail again.
    Getting too much zinc and phosphorus in your cat with cause it to fail. So using the right oil is important. Don't use high zinc/ZDDP oils, diesel oils, or oils that aren't strickly API SN rated because those will foul the catalytic converter more quickly. But if you're burning oil in the first place then you're burning a lot more bad stuff in your catalytic conver even with good oil.
  17. ETC(SS)
    6,555
    There have been "reports" of Elvis running a doughnut shop in downtown Memphis, or for-real aliens driving funny little tic-tac shaped "UFOs" that only seem to show up in military ops areas.
    This is why many fathers would rather their daughters work in a brothel than study to be a journalist.
    Journalism is less honest work sometimes.
    As stated above.....G2 Priuses are SULEVs (Super Ultra Low Emissions Vehicles.)
    So, when we're NOT talking about autocracy run amok, one "might" presume that a properly maintained and well running ULTRA Low Emission vehicle might meet local standards.....or even one of those dirty, nasty LOW emissions vehicles.;)
    There ARE probably cats out there that are little more than bloated straight pipes, but I'm guessing that the marketplace handles these fairly efficiently since most of the mail order parts houses have a guarantee for their parts - or at least a FEEDBACK loop for their customers....otherwise we'd have more substantial evidence that Non-OEM cats fail to meet emissions standards than "there have been reports"
    Sometimes?
    ...nothing.
    Let's pretend that you're working for a dealership that struggles even to meet the low honesty standards journalists set for themselves.
    OK?
    So....one of your victims comes in with a middle-aged Prius that's spitting the Duuuuude! code.
    You're behind in your alimony payments and your former hubby is threatening legal action, and you need another botox treatment.
    WHICH would YOU replace?
    The faulty O2 sensor or the good catalytic converter AND the O2 sensor? ;)
  18. Isaac Zachary
    1,875
    886
    I was referring to people here on Prius Chat mentioning that their aftermarket cats not passing actuall emissions:
    At least that's what I understood.
    Lots of places don't check everything. Lots of places, like where I live, don't even check emissions at all. It is very likely that aftermarket catalytic converters meet minimum requirments. Of course there's also the quesiton about longevity.
    Another thing is I wished people would post their actual emissions test results. We have really no idea what the difference is between an aftermarket cat and an OEM.
    "Sometimes" is correct. But I would never trust a mechanic that wants to change just the catalytic converter, or even less a mechanic that wants to change both the O2 sensor and catalytic converter. Catalytic converters fail for a reason.
    It's kind of like replacing a warped head. It warped for a reason and if you don't fix the reason it will just warp again. It makes absolutly zero sense to replace a fouled cat and not address something else unless the reason is because the car has an extreme amount of miles on it.
  19. ETC(SS)
    6,555
    Start a thread and solicit results.
    For example.....here's mine (for 4 GMCs and a my work Prius)
    I live where temperature inversions are not a prominent weather feature and people actually KNOW the definition of 'smog'. However (comma!) since I try to be a responsible steward. all of my cars are in good running condition and they are 52-state emissions compliant.
    This means that....if somebody jacks the cat off of my work Prius, its cat would be replaced by my beloved company with a $250 non-oem cat that would BOTH extunguish the CEL and allow the car to meet 50-1/2 state standards (not sure about NYC) for ACTUAL (real world) emissions.
    It's a STANDARDS thing....which involves equality....NOT equity.
    (all pigs are equal)
    We have FEDERAL standards:
    All EPA Emission Standards | US EPA
    AND?
    Since states are (sometimes) allowed to set their own standards, sometimes you have to exceed dot.DOT.dot.gov standards.
    Companies like Amazon do not do a very good job at keeping cheap, sometimes non-functional knock-off junk from being sold. They're basically eBay with warehousing and a more robust delivery system.
    HOWEVER (comma!) given the fact that G2 (and now G3) cat thefts are rampant, and a fair percentage of cats are being replaced in zip codes that do NOT begin with 90, AND given the facts that many states have emissions standards and the OEM cats are 5X the cost of the SULEV cats........I'm "guessing" that hollowed out cats aren't a widespread thing........otherwise, WHY have TWO o2 sensors? ;)
    #19 ETC(SS), Jul 28, 2021
    Another and Isaac Zachary like this.
  20. Isaac Zachary
    1,875
    886
    That's a great idea! Maybe they're not that different, or mayber there terrible different. Or maybe there's even a brand out there better than OEM. But you never know until you find out!
    All OBD II cars (1996 and newer) have at least two O2 sensors. One (set) acts as an AFR gauge and the other (set) as a catalytic converter CO and HC efficiency gauge (it doesn't do much to show how much NOx is being reduced.)
    #20 Isaac Zachary, Jul 28, 2021
