Confused - display audio vs Nav radio
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by David A. Needleman, Nov 8, 2016.
  1. David A. Needleman
    David A. Needleman Junior Member
    23
    Pittsburg CA
    2013 Prius Plug-in
    I am a little confused. I have been scouring for information on how to update the maps in my PiP with the 6.1" "display audio" with the GPS mapping navigation feature. I see there is another more advanced radio head with the 7.x" display and the Nav button.
    What's the difference? My maps app provides turn-by-turn voice prompted routing, etc etc. What does the other do in terms of navigation that mine does not? Are there separate mapping updates for these two units (display audio with maps, and the Nav radio)?
    Also, can I update the maps on my display audio with maps (navigation) and if so, how and for how much? Or, since it's one of the Apps, will it update itself and the mapping data through my cellular data connection?
    The two different higher level audio systems both with navigation is a bit confusing to me, so I'd like to get some clarification.
    ~Dave
    #1 David A. Needleman, Nov 8, 2016
  2. David A. Needleman
    23
    Pittsburg CA
    2013 Prius Plug-in
    found some of my answers, but is it true the maps can only be updated by the dealer?
  3. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    That is true.
  4. Tideland Prius
    16,664
    There were two head units offered for the Prius Plug-in.
    Base models got the 6.1" Display Audio system w/ navigation. It runs off a software that eerily looks like a Garmin software. The nav is run off an SD card I believe.
    Higher models had a 7" high resolution screen w/ nav (In the brochure, it's "Premium HDD Navigation"). It runs Toyota's proprietary navigation system off a built-in hard drive. You update via USB I think.
    Both require the dealer to update. I think the 7" version will take longer since the dealer has to upload the maps from the USB stick that they keep at the dealership. The 6.1" versions.... I think it's a simple swap of the SD card.
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If you just got your PiP. I'd recommend you hold off on upgrading it until you've used it on a daily basis. It is pure utter trash. Don't know what the cost will be to upgrade but is sure to exceed $100.
    I didn't have a smartphone at the time but I literally went out and bought a Garmin for $80 that comes with lifetime updates after the Prius gps lost signal in a tunnel and decided after I emerged that I no longer wished to continue to my destination and stopped navigation.
  6. David A. Needleman
    23
    Pittsburg CA
    2013 Prius Plug-in
    I've given the onboard navigation some testing, and until last night thought it was OK (not great). Last night I put it to a test. I have dynamic re-routing enabled. Leaving work, I set Home as my destination, knowing I was going to take a different route than the GPS calculated.
    Long story short, as I proceeded on the different route, the GPS unit kept trying to route me back to the other road, instead of calculating a route on the road I was on that led to my destination.
    For those in the bay area CA this will make more sense:
    I commute from San Ramon to Berkeley and back. Normally I take 80->580 to get home, which was the route calculated. Due to a major accident I re-routed down 880->237->580. The GPS unit kept trying to get me to go on a surface street and circle back around to take 580 through Oakland (which was a nightmare last night). It just seemed wrong that it kept trying to route me back to 580.
    Perhaps that was by mileage still the shortest route, but it would not have been the fastest. Last night on the road was a loss anyway - 2 hours to drive 31 miles...
    Thanks also for the info on the map updates. Since my iPhone does a much better job, I'll probably get a holder for it so I can use that instead.
    mmmodem and bisco like this.
  7. bisco
    52,740
    good idea.;) i was lost in new york city, gps was useless. had to find my way with signs and landmarks.
    David A. Needleman likes this.
  8. David A. Needleman
    23
    Pittsburg CA
    2013 Prius Plug-in
    Can see that happening. In my younger days, before getting into IT work, I drove 18 wheelers into NYC, the Bronx and Manhattan. Can get lost real easy, this was before GPS receivers.
    Even with the bad commute, car said it got 52 mpg last night. Love my Prius!
