Confused.
Discussion in 'Gen 3 Prius Main Forum' started by Nphra, Nov 15, 2024.
  1. Nphra
    Nphra Junior Member
    38
    Hello it been a while. Hope everyone is doing well.?
    Can soome tell me which one is ABS Booster and ABS Pump ?
    There is conflict information out there, even in YT.
    See attached photo
    Thank you
      File size:
      33.5 KB
      File size:
      231.2 KB
  2. Tombukt2
    Tombukt2 Senior Member
    11,995
    2,119
    Durham NC
    Whatever they're called You better be replacing them as a pair like Toyota recommends or you might be paying labor twice just for fun
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,488
    5,812
    Texas Hill Country
    The pump is 1.jpg.
    Where/what is YT?
    Nphra likes this.
  4. Melthias
    Melthias Member
    99
    36
    Southern Maine
    YouTube
    Nphra likes this.
  5. Nphra
    Nphra Junior Member
    38
    Thank you everyone.
    My pump keep making Zzzzzzz noises.
    I guess I bought the Booster as shown in picture 2.jpeg. I will look the pump.
  6. ChapmanF
    17,180
    Those are the exact noises it's supposed to make. Only a problem if it makes them at the wrong times or too often.
    If that's the case, the problem can still be in either of the two assemblies, so there's no one easy answer what will solve your problem. It's often the booster, as there are more valves inside there to go possibly bad.
  7. Nphra
    Nphra Junior Member
    38
    Thank you, so much for your inputs.
  8. Nphra
    Nphra Junior Member
    38
    Thank you
  9. Nphra
    Nphra Junior Member
    38
    Quick updates:
    I took the gamble and replaced just the booster it work. No more Zzzzz sounds from the pump, only when I step on the brake.
    However, all the ABS, traction lights come on and I did do the bleed job and it work great. Does anyone knows how to reset the lights without scan tools or Techstream tool ? Or let me know which cheap scan tools can do this job ? Please let me know. Thank you
  10. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    You can buy a obd scan tool Fromm Walmart and write them down. Clear codes with the tool. If The codes comeback, continue troubleshooting using the codes as reference points
  11. ASRDogman
    ASRDogman Senior Member
    7,109
    3,713
    What did you use to properly bleed the system and set it up?
    You need techstream, or the D7, D8, or some other tool to set it up.
    And that tool will clear the codes.
    Without setting it up correctly, you run the risk of not having brakes.
    And causing a wreck, and injuring some innocent party....
    Brian1954 likes this.
  12. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    You did NOT bleed the brakes correctly unless you used Techstream or similar scan tool. That is one reason the warning lights are now on. There are many threads in this forum about brake bleeding after replacing the brake actuator. Do a search and a lot of reading to learn more.
    ASRDogman likes this.
  13. rjparker
    9,488
    5,812
    Texas Hill Country
    Here are some basics on doing this with Techstream
    An alternative is to have a dealer or qualified independent with experience in this procedure to do it for you.
    Frontporch and Brian1954 like this.
  14. Mendel Leisk
    40,457
    Get dealership to remedy the lights? Keep in mind: they’re not on JUST to annoy you.
  15. rjparker
    9,488
    5,812
    Texas Hill Country
    Use the dealer if you don’t have Techstream to run the procedure. The op has already replaced the master cylinder.
  16. Mendel Leisk
    40,457
    Understand that, and am assuming he doesn't have Techstream.
  17. Nphra
    Nphra Junior Member
    38
    Thank you, all.
    I order Techstream V18 and should arrive today. I will use the instruction rjparker provide.
    Thank you so much.
  18. rjparker
    9,488
    5,812
    Texas Hill Country
    Installing Techstream requires a pc and the hardware interface you probably bought. The instructions above are once you get it installed which should have a separate set of instructions.
  19. Mendel Leisk
    40,457
    The lights, that is. Actually applicable for the lights and the dealership, I suppose.
  20. Nphra
    Nphra Junior Member
    38
    Updates:
    Installed tech stream and able to communictaion.
    Butwhen i get to the bleeding process i fail, see photo,
    Any suggestion ?
