Confusion Over Correct Prius Tire Size
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jaqueh, Feb 3, 2015.
  1. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    I was wondering if you guys could tell me what the correct size for the Prius should be:
    OEM USA is 185 65 15
    Everywhere else is 195 60 15
    But I read on the LRR thread that the 195 65 15 can correct the speedo error?
    Can anyone confirm with this? I want to get a wider tire, but I don't want to install one that is going to be detrimental to my car. I want to make sure that I can go with the most common tire size now, which is 195 65 15. Can someone who runs these tires on the Gen II chime in?
    Thanks,
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Sorry I cannot help much with your request except that going to 195/65/15 will indeed help correct the speedo error as well as the MFD MPG readout. Your oddo will slightly under read you millage though by about 1.5% depending on the tyre manufacturer.
    There is an other tyre size fitted on the touring model in the US of 195/55/16, and the same size is fitted throughout the UK and Europe. Many including myself fit 205/55/16 to not only improve speedo accuracy, but greatly enhance the road holding, and strait line stability.
    John (Britprius)
  3. jaqueh
    341
    199
    San Francisco
    Ok. I do not have the touring model so I am on 15" wheels, but will the 195/65/15 fit perfectly on the wheels without any compromise in safety. Also what are the mpg differences of having a different size tire
  4. Britprius
    5,194
    1,922
    The 195/65/15 tyres fit perfectly well they are only about 1.5% lager in diameter or less than 1/4 inch bigger from the centre of the wheel to the outside of the tread.
    The difference in MPG will be dictated more by the actual tyres you choose (manufacturer and type) than the size change.
    I know your on 15 inch wheels, but I found an improvement with 16's going from 195 to 205's. You do not always take a hit. The MFD readout may show a slightl lower figure but this is a more accurate figure than the optimistic figures given with the smaller tyres.
    John (Britprius)
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    205/60r15 work fine on the base wheels, and look better too. corrects the speedo too
  6. jaqueh
    341
    199
    San Francisco
    Yeah I guess my only worry is that if I don't like the tires they might not accept the return if I didn't use the OEM size
  7. 69shovlhed
    2,170
    752
    Delaware
    get Michelins and you won't be dissappointed
  8. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    I first had the OEM 185/65/15 then I had 195/65/15 (Good year assurance fuelmax) and yes that corrects the odo reading, I liked it as I got better handling however It seemed that at every bump it hits something inside as the diameter is a little large and makes a sound, now I have 205/60/15 Michelin defenders and like it very much, very nice handling, smooth quiet ride, looks good and since the dia is a little smaller than 195/65/15 it does not hit the inside, however due to it being softer tire I got a little hit on MPG (approx 10%), to keep the MPG I should have gone with 205/60/15 Goodyear assuarance fuelmax which is the only other LRR available in this size. 190/60/15 will make the odometer reading even worst as the dia is even smaller than 185/65/15 but not sure about the ride as I have not tried that size yet.
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    185 65 24.5"
    195 65 25"
    205 65 25.5"
    I think the 25.5 outer diameter would be very close to making the speedometer accurate, when new.
    Yes you can increase the overall circumference from 24.5 to 25.5 if you wish, less torque when starting up from zero, better mpgs overall.
    These are all 65 series, yes you could go 60 series and be wider, slightly less mpgs, slightly more grip.
  10. SWprius08
    170
    Los Angeles (SFV)
    205/65/15 might not be a good option for gen 2 prius.
  11. 69shovlhed
    2,170
    752
    Delaware
    205/60r15 works great. had em on the '04, have em on the '05, and can't wait for the suck integritys on the '06 to wear out.
  12. SWprius08
    170
    Los Angeles (SFV)
    I have that size right now, 5k miles michelin defender, which one did you have?
  13. jaqueh
    341
    199
    San Francisco
    So 195/65/15 doesn't rub against the car because of the taller profile?
  14. SWprius08
    170
    Los Angeles (SFV)
    I am not exactly sure what "rubbing" means in automotive world, what i observed is that the tires did not touch anything inside while rolling which would cause the tire to wear unevenly, however as I mentioned earlier it will hit something (possibly struts) inside more often on even small bumps and that sound made me uncomfortable.
    Which make are you thinking of getting?
  15. jaqueh
    341
    199
    San Francisco
    I am going with either Defenders or Conti ProContact with Eco Plus
  16. SWprius08
    170
    Los Angeles (SFV)
    Having used both 195/65/15 and 205/60/15, my recommendation would be the 205/60/15, however the conti's are not available in that size, only defender. Good luck! Do update with what you decide and your experience.
  17. jaqueh
    341
    199
    San Francisco
    Have you used both tires? How are the defenders? The most important features in tires for me are longevity and then tread life.
  18. SWprius08
    170
    Los Angeles (SFV)
    Out of the 2 I have only used defender, that is my current tire since 5000 miles. Had to play with the air pressure to get the comfort i needed. Coming from GY fuelmax my Mpg has gone down a bit (about 10%) and based on my research mpg will go down with conti as well. Michelin does offer 30 day return policy, and I believe conti does offer the same as well, look into that and see what might work the best for you.
  19. Mendel Leisk
    41,894
    I kinda doubt that. It'll likely "correct" the speedometer, and throw the odometer off slightly.
    SWprius08 likes this.
  20. jaqueh
    341
    199
    San Francisco
    What do u recommend in this matter?
