Connecting to multiple bluetooth phones.
Discussion in 'Gen 2 Prius Audio and Electronics' started by jeffk, Feb 27, 2009.
  1. jeffk
    jeffk New Member
    I am hoping there has been some new info found since I last looked a couple years ago.
    Anyone discover a way to overcome the limitation of the Prius only auto-connecing to one phone until you select another phone?
    (Example: it detects my phone everytime I get in the car but when my wife drives it it won't detect hers unless you go through the menu and select that phone)
    Thank You!:)
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    You have to select the default phone. Then it will auto-connect if set for that.
    There is no way to auto-connect two phones, only one at a time.
    Tom
  3. jeffk
    jeffk New Member
    Thanks.
    I appreciate the response.
    I was hoping a work around had been discovered but I guess not on this one.
    Thanks again.
  4. qbee42
    18,058
    3,073
    Northern Michigan
    There isn't a work around because it's not considered a problem. It was designed this way to avoid a potential race condition with two auto-paired phones.
    Tom
  5. ehan
    ehan New Member
    there should be a way to just make it default in the order they're added
