Consensus on preemptive thermostat replacement?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by mrand, Mar 29, 2025.
  1. mrand
    mrand Junior Member
    DFW
    2014 Prius v wagon
    Coming up on 140k miles on my 2014 Prius V and I'm going to do a preemptive water pump replacement while cleaning EGR.
    I see various discussions about people replacing their thermostats when they have coolant issues, but how many have actually been bad? I'm weighing the relatively minor cost of thermostat + housing replacement vs. the minor risks associated with replacing it (mainly creating a problem or leak where there isn't one right now).
    Thank you!
  2. frodoz737
    frodoz737 Top Wrench
    4,503
    2,426
    33
    EGR clean and water pump R&R? Yes..replace the thermostat.
  3. rjparker
    rjparker Tu Humilde Sirviente
    9,488
    5,812
    Texas Hill Country
    If money is a limiting factor I would forego the thermostat if it meant I could get an oem pump rather than aftermarket.. Regardless I would keep my old one because I believe if it's not broken don't fix it. 330k miles later on my v, originals are still fine but I have drained and filled the coolant about ten times.
  4. Mendel Leisk
    40,457
    #4 Mendel Leisk, Mar 30, 2025
