considering buying a Prius prime XLE 2020MY with 2500 (yes 25 hundred) miles.I
Discussion in 'Prime Main Forum (2017-2022)' started by Toehee, Apr 28, 2024.
  1. Toehee
    Toehee Junior Member
    Conesus,NY
    2020 Prius Prime
    It was a gov’t agency car. Battery check shows all good cells. Drives and looks as new. Engine upper and lower bay clean. I wonder about engine seals drying from not being driven. It will cost me $20k after used vehicle rebate. Thoughts?
  2. BiomedO1
    BiomedO1 Senior Member
    1,435
    782
    SacTown, Ca
    That's a great find. I believe the traction battery and emission system is still under OEM warranty. You may have to replace the starting battery if it wasn't plugged into a battery maintainer.
    49,358
    i would jump on it
  4. Louis19
    Louis19 Active Member
    374
    335
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    go for it , do an oil and oil filter change
    all the best
  5. Danno5060
    Danno5060 Member
    195
    78
    Wyoming
    Sounds great. Hopefully those weren't 2500 upstate New York salted road winter miles, but that still doesn't seem to be a problem. Check to see that it's not a rebuilt wreck too.
  6. drash
    drash Senior Member
    2,476
    1,251
    Upstate NY
    I've seen those around the NYSDOT regionals with them plugged in all the time. They don't get used much at all. It's not the engine seals that would be the problem but check for tire rot and if it is a DOT vehicle, they keep maintenance records. And as @Louis19 mentioned I'd be doing an oil/filter change. Might also want to make sure they still have the EVSE in it.
  7. Toehee
    Conesus,NY
    2020 Prius Prime
    Bought it. Will be performing oil change tomorrow and adding dynamat to the doors real soon.
  8. Leadfoot J. McCoalroller
    7,131
    6,679
    Pennsylvania
    2018 Prius c
    Congrats, sounds like you found a good car!
    Fresh 12v battery, tires & wipers would be about right for a 2020 that sat around.
    Quieter tires reduces the need for bonus sound insulation.
    ...but our car has both, it's nice.
