Considering purchasing a 400K mile Prius C
Discussion in 'Prius c Main Forum' started by SidTGray, Apr 25, 2017.
  1. SidTGray
    SidTGray Junior Member
    Savannah, GA
    2002 Prius
    I
    Am I crazy for considering purchasing a 400,000+ mile Prius C? I've owned a 1st gen Prius and a 2nd gen Prius. Both got over 300,000 miles. I've now run across a 2012 Prius C with 412,000 miles. The Toyota dealer is asking $4K for it. It is a one-owner car and was purchased new from this same dealer.
    My understanding is it is on the original battery, inverter, etc. Had pretty regular maintenance up until 250K miles. From there I can't track what has been done. I've never driven a car with 400,000 miles on it before. Much less a Prius.
    I've wanted one of the "C" versions -- and did not want to spend much on one. From a drive standpoint, it drives pretty well. If for a few things, you would have no idea it had so much mileage.
    Curious to know from other "C" owners their thoughts on a car like this? Any track record to follow for this particular car and high mileage?
    #1 SidTGray, Apr 25, 2017
    49,448
    life is short, go for it!:p
    Aaron Vitolins likes this.
  3. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    All of the Prius models have a pretty good reputation for battery longevity, but 400K miles implies an awful lot of use. If that's really the original battery then I'd advise you to wrap the battery replacement cost into your budget. If you're comfortable paying for both the car and a battery replacement, then it might be for you. And if it turns out that you don't need to replace the battery then you come out ahead.
    John in Vermont likes this.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I'd drive it and keep a close eye on the battery meter. It can't have a ton of battery capacity left. Check to see if the battery level swings up and down quickly on the meter.
    I personally would be worried about high rate of oil consumption at that amount of miles. The 1.5 engine is good. And you don't have to worry about head gasket issues like the 1.8 engine. I would say absolutely don't buy it if it was a liftback with the 1.8 engine. They have a rough time making 250,000k sadly
  5. bisco
    49,448
    there's another member who bought a lift back with 400k, and drove it another 100k without issue until a tree fell on it. but he doesn't want to fix it because somehow, 500k is a magical number where the car is going to turn into a money pit.o_O
  6. fistofthesouthstar
    fistofthesouthstar New Member
    US
    2016 Prius c
  7. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    4 grand for a 400k mi. car? Get real! It could go a lot more miles, or fail on the way home. 4 grand's a whole pile of money for an old, probably unreliable car.
    I'd let this one pass and look for something else. I've got a real nice 03 for $3000, 148,000 mi., if you want to jump on a plane and come get it.
    WHCSC likes this.
  8. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Don't waste your cash
  9. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,611
    Somewhere in Wisconsin
    2013 Chevy Volt
    If it was under $1500 it would make a good beater car
  10. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    If it's something that has been well maintained it could last forever. However the 400,000 miles would give me pause but I'd say Priuses are very reliable and you can always buy used parts off of wrecked c'S. I'd rather have a C as a Gen 2 any day
  11. InPriusLove
    InPriusLove Member
    165
    40
    California, US
    2015 Prius c
    Damn tree. (Not mine but the ending is sad)
    Buy the car, prepare for maintenance and battery, and know that a true classic never dies.
    I once knew a 1967 Camaro in its third engine and 600k miles back in the eighties. It probably is still running. The one owner took it to shops that gave lifetime guarantees. Paid for brakes once with Midas for example.
    Synthetic fuel is what the Prius C takes and if it leaks which doubtful it would significantly, just keep monitoring it. Also use fuel system cleaners.
  12. CowichanBC
    CowichanBC Junior Member
    Duncan, BC, Canada
    Technology
    Good luck with your decision. I would think that you should offer a low bid, say $2900. How many other people would gamble on the car with that many miles? (My 2012 Prius C has barely 60,000 miles on it.)
  13. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    Nice! My 2012 C only have 27,000 miles on it
    CowichanBC likes this.
  14. Mendel Leisk
    38,710
    Yeah that's a heavy amount of miles. Consider: what are seller's other options? I don't think they will get any other takers, at the price, with those miles. Offer 2K, with room to go up a bit? Also, go for an extended test drive, before even making the offer.
  15. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Hey offer the dealer $1000, take it or leave it. At that price I imagine he still would make a nice profit. And 1k is all that thing is worth!
    vegan and Mendel Leisk like this.
  16. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I drive a little more than average and I only have ~79k miles. 400k miles on a 2012 is a whole lot of miles. 80k miles/year. If the dealer has proof of maintenance, that's not too bad of a deal, but if he can't document every single oil change... all 40 of them, along with the major parts and fluid like the inverter and coolant fluid, I would walk.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Well....
    Since it's not my 4 grand...my instinct is to go YEAH! GO FOR IT!....then wait for the posts about battery replacement, engine replacement and transmission replacement. But.....
    You'd have to work pretty hard to put that many miles on a Prius c that quickly.
    Really? How are you about gambling? Because it would be a roll of the dice. You could buy it and be talking about an economical 100,000 mile stint, or you could be talking about what a mistake the whole thing became.
    There is no magic, and 400,000 miles on any vehicle is a lot. Hard to believe at least some expensive repairs might not be on the horizon.
    And finding a comparative track record? Also probably pretty hard to do. I'm thinking running 2012 Prius c's with 400,000 miles or more on them are nearly non-existent. If you buy it...you might be the only one.
    Crazy?
    Well...gamble only if you can afford the loss.
    If battery failure, engine failure or transmission problems, or other high end repairs would become instantly a huge problem?
    I'd pass.
    And know of course, it becomes $4000 plus whatever the cost of future repairs become.
  18. mark schofield
    mark schofield Junior Member
    I'd buy it for fun, like buying an old VW bus. If I was really into a Prius.
    The Electric Me likes this.
  19. 08PriusXSJ
    08PriusXSJ Junior Member
    42
    Connecticut
    I will definitely not buy it even under $1K. I bought two Prius from private owners, $3.8K for a 08 Prius with 96,000 mile and $7.1K for a 12 Prius C2 with 20,432 mile.
  20. jimnjo
    jimnjo Member
    117
    2015 Prius c
    too much money for too many miles, but a low ball offer as advised above makes some sense. The dealer almost certainly has $1k or less in it, don't you think? A friend just turned 300,000 on a gen one. It is on second engine and first battery pack...for what that is worth.
