Considering this salvage prius - Should I expect problems?
Discussion in 'Gen 2 Prius Main Forum' started by wargarbl, Sep 10, 2013.
  1. Talk him down some, maybe...
    2 vote(s)
    22.2%
  2. Hell no
    7 vote(s)
    77.8%
  1. wargarbl
    wargarbl New Member
    I saw an ad on craigslist and checked this 06 Prius out, fully loaded. Took down the VIN and surprise surprise, it wasn't just a door dent, it looks like the entire back end was totalled.
    You can see the damage by googling JTDKB20U767513876 on salvagebid since I can't post links unfortunately. It's under 750174217-2006-toyota-prius
    Looking at the car now you can't even tell it was repaired at least from the outside but lifting up the cargo mat shows a gnarly weld above where the right wheel should be and some bondo. Pretty sure they replaced some part of the back frame but I don't know how much could be replaced.
    How much is she really worth? He's asking 8.5k for 91k miles on the odo.
    Is it too much trouble down the road to bother with salvages?
    Thanks for reading!
    51,155
    welcome to priuschat! not much, are you a good mechanic/electrician? all the best!(y)
  3. wargarbl
    wargarbl New Member
    Thanks bisco! This would actually be my first car but I'm looking forward to learning everything I can about her. Pretty much a DIY guy as long as I have the tools and the time.
    51,155
    these cars are complicated, and salvage title has led to some frustration here if you search threads.
  5. boppo
    boppo Active Member
    799
    139
    Owego, NY
    IMO they are asking 2k to much.
    PriusGuy32 likes this.
  6. wargarbl
    wargarbl New Member
    What should I look for in the rear for signs of imminent failure? I'm going to be taking out the spare wheel and checking for water, anything under the car I should look for?
  7. bisco
    51,155
    i'm no mechanic so i can't advise on structural issue. what would you do if in a couple thousand miles the rear tyres started to wear funny? i would definitely open the battery box and look for corrosian etc. CAUTION: HIGH VOLTAGE!!!:eek:
  8. northwichita
    481
    102
    29
    Wichita KS
    I believe another factor is many car insurance's won't cover more than liability for the vehicle, take this into account in the price, or at least check it out first with your insurance co.
  9. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Unless you're looking for an Albatross to put around your neck, I'd avoid it.
  10. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I am no mechanic or body man, but looking at this picture I cannot see why anyone would want to buy this car even if it looks okay today. There was quite a bit of visible damage. There is always more that is unseen. To me it is a problem waiting to happen. I would look elsewhere.
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    I dont like it either.
  12. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    price is too high
  13. vskid3
    vskid3 Active Member
    773
    228
    If you're mechanically inclined and could fix or at least spot any future issues, it might be an ok car. I wouldn't pay more than $6k for it, though. I wonder how much work it needed to just be driveable, I might have to get me one (pre-fix) in a couple years, pound out the dents and have a nice beater.
  14. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    If you could get it for $4k and bank some money for potential future problems based on the mileage/age and most importantly - collision that salvaged it - then I would do it. Otherwise, heeeeeeelllll no. Run, dont walk.
  15. scotrinaf
    scotrinaf Junior Member
    37
    Blountville, TN
    Both of my 2008 Prius had damage, one on the rear end, the other in the driver's side doors, neither one has been negatively affected best I can tell (Other than very minor cosmetic imperfections)
