Constant beeping sound?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AKCMommy, Aug 3, 2009.
  1. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    Yesterday, my 2007 just started beeping. It's not exactly constant, but it isn't rare either. It's intermittant but frequent. It sounds similar to the beep when I touch my screen, but it is coming from the left front of the dash.
    I unplugged my cell, ipod and left them at home. i swapped my fob for my DH's...no avail.
    Any suggestions?
    Thanks!
  2. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    Any warning lights come on the dash? Seatbelt? Did you leave something heavy on the passenger seat? Does it do it every trip, or just sometimes?
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Have you changed the battery in your fob. A weak battery will cause the car to beep.
  4. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    Passenger seat empty. No warning lights. It is not the seatbelt sound. That is a different beep than the one I heard yesterday.
    The new beep sounds like someone is touching the screen over and over and over very fast.
    It is doing it every trip. But just started yesterday.
  5. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    Repeatedly, even if the car is off?
    I left my fob at home and traded it for my husbands because i thought that it might be the fob. Still beeping.
  6. firepa63
    1,761
    208
    The beep with a weak fob battery will usually occur at shutdown. Do you have a cell phone or pager in the car that has a message waiting? Been there, done that.
  7. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    No. I took all of the electrical equipment out of my car.
    It's empty. Still beeps.
  8. firepa63
    1,761
    208
    How about the Maintenance Required alarm? Has it been close to 5000 miles since it was last reset?
  9. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    No. It's good there.
    I realized that I didn't tell you all the # of beeps. In a 10 minute drive, it's probably 100 beeps.
  10. firepa63
    1,761
    208
    You got me ... I haven't heard of that one before. Have you noticed if the Passenger Airbag light comes on when a beep occurs?
  11. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    No. i have not noticed that.
  12. firepa63
    1,761
    208
    Maybe it's time for a trip to the dealer...
  13. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Is it high pitched, loud, and steady over the times it goes
    off? Any relation to use of the brake pedal? It might be the
    brake pressure alarm, and if you can stop and get your head down
    under to peer around up into the driver footwell while it's
    happening you may be able to localize the source. If it's
    coming from the little grey box attached to the brake computer
    mounted above the pedals, you have a hydraulic pressure problem.
    See this pic, although in real life the little
    grey beeper has a two-wire connector going into the front.
    If it's coming from the lefthand stereo speaker in the door [or
    similar depending on which stereo you have] then it's more related
    to the screen and button-presses.
    _H*
    Brendank likes this.
  14. firepa63
    1,761
    208
    Do you get the beeps if someone is sitting in the passanger seat?
  15. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    I made an appt yesterday to take it in tomorrow. They have it scheduled to have it all day. I just thought that perhaps someone here might have an idea what the problem may be.
  16. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    It sounds like it is coming from somewhere high. Like the speaker in the dash near the tiny window. It could be coming from the speaker in the door, right near there too. It is not coming from near the pedals.
    I was thinking that it has something to do with the screen and button presses. But there was nothing touching the screen to make that beeping sound. Also, when I touch my screen, the beeping seems to come from somewhere more central in the dash. The unknown beep and the screen beep do not sound like they are coming from the same place.
  17. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    That's a good question. I'll find out. I'll ask someone to sit in it for a spin around the block.
  18. firepa63
    1,761
    208
    Any change?
  19. AKCMommy
    AKCMommy New Member
    45
    Rose City, Oregon
    So, the dealer could not replicate the beeping...go figure.
    They told me that they drove it a couple of times. Granted, it is about 30 degrees cooler here today than it was on Sunday when it was beeping up a storm. GAH.
  20. StanleyTailor
    StanleyTailor New Member
    San Francisco
    I have the same issue its happens only if you go 60 miles per hour on freeway and its a long turn on left or right ! Im assume that it is some sensor that controlls the steering on high speeds to prevent sleeping of the driver!
    Im just about to replace steering rack shaft and pinions
