Constant High Pitched Whining
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by LonelyAtTheTop, Oct 5, 2020.
  1. LonelyAtTheTop
    LonelyAtTheTop New Member
    Detroit
    Hey everyone!
    I have a 2012 Prius C and for about a month there has been a constant super high pitched noise coming from the center console area. It’s not a normal hybrid noise, for sure. I have turned off all A/C, heat, and audio and it’s just super loud. Is it some kind of vacuum leak? Anyone else had this problem?
    If this problem has been solved before please direct me there? I did a quick search but I’m sure everyone describes things differently!
    thanks in advance!
    49,378
    how many miles on her?
    wheel bearing maybe?
  3. LonelyAtTheTop
    Detroit
    Constant, whether moving or not. Whether the gas engine is running or it’s in EV.
  4. LonelyAtTheTop
    Detroit
    Oh I misread your reply. It is a 2012 with 67k miles
  5. PriusCamper
    PriusCamper Senior Member
    11,056
    4,499
    Pacific Northwest, USA
    Perhaps try to isolate which system is making the noise by removing fuses?
  6. ChapmanF
    15,441
    Any, umm, lights on the dash?
  7. LonelyAtTheTop
    Detroit
    Nope. No lights on the dash. Everything seems normal except the sound.
  8. bisco
    49,378
    Center console meaning under the armrest?
  9. LonelyAtTheTop
    Detroit
    Nope, sorry for the lack of clarity. It seems like it’s coming from behind the AC vents in the center of the dash. Initially I thought it was an AC problem, but it happens constantly, even if the AC is off. I was thinking maybe it’s a vacuum leak somewhere?
  10. bisco
    49,378
    does it have an aftermarket alarm?
  11. LonelyAtTheTop
    Detroit
    Nope. Completely stock. Doesn’t sound electronic at all. If it was a vacuum leak, where would I start looking?
  12. bisco
    49,378
    no idea.
    when you open the hood, and listen there, does it still sound like it is inside the dash?
  13. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Behind the vents, could be the blower, a bearing in the blower fan.
    Z6201V ?
  14. LonelyAtTheTop
    Detroit
    Does the blower run constantly, whether the HVAC system is on or not?
    I will say that since it’s started getting colder (I’m in Michigan) the noise has gotten almost unnoticeable. I still want to get it sorted out, though...
