Constant noise from driver's side? Recording included
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ANfry, Oct 18, 2022.
  1. ANfry
    ANfry Junior Member
    Nashville, TN
    Hello-
    My 2006 Prius has been making this noise every 10-15 seconds. It used to happen only rarely, now I hear it at all times, while driving, while idle, before startup and after. I have searched here to find a similar noise, but most post's audio files are no longer available.
    Any advice or insight is very much appreciated.
    Here is the link again: (the audio has to be turned on in the media player)
    Cheers,
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    That is your ABS pump running to pressurize the brake fluid accumulator. The brake actuator module that the pump and accumulator are mounted to most likely has an internal leak. Eventually, it will get bad enough that it will cause a DTC and the brake warning lights will illuminate. Actuator assembly will need to be replaced. Very common Gen 2 problem.
    ANfry likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Or that's a very bad air conditioning cycling on and off..
  4. ANfry
    ANfry Junior Member
    Nashville, TN
    Thanks,
    I really appreciate the info. Seems like it could be a pricey repair. Is it bad to keep driving it for now until I can get some money together? Or is it an urgent repair that could do more damage if left alone?
  5. bisco
    51,155
    fine to drive it until you get warning lights/trouble codes. could be a long while yet, hard to say.
  6. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    Not really, that noise is coming from the LR of the engine compartment, right where the ABS pump/actuator is.
  7. Tombukt2
    12,214
    2,155
    Durham NC
    Drive it like it's
