Consumer Reports: 2010 Toyota Prius still most fuel efficient car in America
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by cwerdna, Oct 7, 2009.
  1. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  2. bwilson4web
    16,215
    I read the online version from the Consumer Reports web site and found two interesting quotes:
    Also, I noticed:
    • "Accident alert system - Not available" -- in this I somewhat agree because it is an option ONLY in the top of the line. It really needs to be an option for all models.
    • "Daytime running lights - Not available" -- IMHO, I think this is a useful option and should be considered for future Prius.
    • "Tire pressure monitor - Available" -- this isn't standard??
  3. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    Not quite right.
    Tesla claims the Roadster is 2x as efficient as the Prius.
  4. Politburo
    Politburo Active Member
    971
    208
    Tire pressure monitoring systems are required by federal regulation.
  5. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Not really. The Tesla is less carbon fuel efficient than the Prius based on its EPA test results: 28 kWh/100 miles.
    At any rate, the Tesla doesn't run on "fuel" and therefore your claim is inaccurate.
  6. Celtic Blue
    2,224
    139
    Midwest
    As a separate option yes, not bundled. I got saddled with them in my Tundra as part of a package, but DRL's are unsuitable for my use. I had to pay to have them permanently disabled. I would have been happy to have a fuse/switch so that I could re-enable them at other times, but that was not an option.
    If DRL's are all or nothing, nothing is preferable.
  7. drees
    drees Senior Member
    1,782
    247
    How do you figure that?
    Then where did all the carbon come from?
  8. Celtic Blue
    2,224
    139
    Midwest
    I worked through the numbers recently comparing the Volt with the Prius. You should remember it since you posted a thanks to someone posting clearly erroneous information as a rebuttal in that thread. I used a lower kwh/mile value of 0.250 kwh/mile for the electric and it still lost. Use 0.28 kwh/mile for the Tesla from its EPA testing and it will fare even worse. You can even apply the DOE's 0.83 factor for well-to-tank gasoline to the Prius, and about 0.98-0.99 for coal mining, and 0.92-0.93 factor for average U.S. electrical transmission losses if you like. (I'm assuming the 0.28 kwh/mile figure includes Tesla's reported charging losses, 0.86 efficiency, so don't double count that.)
    The Prius still comes out about 17% ahead by my estimate...and I get about 10% better mileage than the EPA combined figure so it is even higher for me.
    Note that I'm not even considering the differential energy cost for the battery production. Full hybrids get more "bang for the buck" from their batteries than any EV does with present battery technology. Hybrids use maybe 1/10th as much battery capacity. Production cost of the additional battery pack is a crude measure of this. Add on tens of thousands of dollars worth of battery and try to convert that into energy consumption over a given vehicle life. (150,000 miles, 200,000, 300,000...it can't be very pretty even with high values.)
    All in, it is likely no contest.
    Well, nobody stuck coal or water in the tank, and electricity is not "fuel." It was a silly statement by the previous poster considering that the article was clearly not referring to electrics. Might as well throw in bicycles or Amish buggies to really muddy the comparison.
    You can't do apples-to-apples with electric, only approximate, because its energy/carbon efficiency varies greatly depending on the source of electricity. For my situation where ~100% of my electric comes from an aged coal plant within about two linear miles of my home I have no doubt about the basis. Electric loses easily to a hybrid like the Prius. That was a bit of an epiphany to me when I finally ran through the numbers. My interest in EV has evaporated since it is a false economy for me.
    By the way, why didn't you ask the other poster to explain himself instead of me? Afterall, the one making the original challenge is the one that needs to back it up with some proof. A carmaker's hype is about as far from proof as one can get...especially when you look at Tesla's numbers and notice the cherrypicking.
    It's not that I wan't EVs to fail or don't see them as a necessary progression. It is that electricity production is so inefficient from a carbon standpoint at present. We still have a long ways to go.
  9. drees
    drees Senior Member
    1,782
    247
    OK, since Shawn didn't post his full numbers, I found these from this web site which appear to be OK on the surface (I did not research the numbers to validate them):
    I was (partially) wrong Climate Sanity
    Basically claims that:
    50mpg = 0.39 lbs CO2/mile
    EV[1] = 0.37 lbs CO2/mile
    EV[2] = 0.58 lbs CO2/mile
    Where EV[1] is the national average for electricity generation (1.34 lbs CO2 / kWh) and EV[2] is coal heavy electricity generation (2.1 lbs CO2 / kWh).
    So what does this tell us? On the whole, going EV is good! We slightly reduce our carbon footprint, significantly improve local air quality where it matters most, and also reduce our trade deficit.
    Sure - if you live in an area where your electricity comes from dirty, old, inefficient coal plants, then yes - you probably should pay a bit extra for renewable power. And even then - there's the previously mentioned benefits, not to mention the fact that the grid is moving away from coal power with it being replaced primarily by renewables and very efficient natural gas.
    Edit: I found this cool website which lets you look up how dirty/clean your electricity is compared to average. The data used is a bit newer than the article above (1999) using data from 2005. I looked up my zip code and my electricity emits 0.724 lbs CO2 / kWh - nearly half the national average. In other words, an EV would be like driving a 100 mpg car in terms of CO2 emissions - not to mention all the other benefits of driving an EV (like the fact that I should have solar panels on my roof by the end of the year, thereby reducing the emissions of my electricity even more!)
    3 people like this.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Drees, well put.
    I think though that a couple of other things should be kept in mind in the balancing act of coal vs oil.
    One is Nox and Sox emmisions,
    the second is ground toxics and destructions. Pictures of the lakes of coal slurry in the south are a nasty site, as are oil spills. I honestly do no know which is worse.
  11. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I put in my zip code and I got this result
    42.3% - Gas
    17.7% - Hydro
    16.5% - nuclear
    11.9% - Coal
    9.4% - Non-Hydro Renewables
    1.2% - Oil
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Since I live in the same area my results were the same. This is how emissions output stacked up against the national average.
    Nitrogen Dioxide 0.62 vs. 1.94
    Sulfur Dioxide 0.53 vs. 5.26
    Carbon Dioxide 724 vs. 1329
  13. SageBrush
    11,627
    2,533
    Southwest Colorado
    Average sure, but we care about marginal demand when we 'plug-in'
    btw Justin, how do your local smokestack Nox and Sox compare to the Prius ?
  14. drees
    drees Senior Member
    1,782
    247
    Marginal demand around here (California) is nearly all natural gas - very clean. Because of air quality regulations NOx and SO2 emissions are well below national averages for similar plants - CO2 emissions also tend to be below average.
  15. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    50 mpg, baby, and still going strong. Best car I've ever owned.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I want to try and answer your question but I'm getting chemo right now and my brain is not working right. I'm having somer weird reaction which is causing slurred speech and severe muscle twitching. lol I'll get back to you tonight when I get out of here and this effect goes away. :)
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Mine is 44% nuclear, 35% gas and 20% oil.
  18. Prius101
    Prius101 Paid off Prius Member
    118
    Port Orchard, WA
    Puget Sound Energy has quite a mix:
    non-hydro renewables: 2.3/2.1
    Hydro: 48.6/6.5
    Nuclear: 3.3/19.3
    Oil: 0.3/3.0
    Gas: 10.8/18.8
    Coal: 34.4/49.6
    Note that we use more hydro than coal, at least.
  19. fuzzy1
    10,452
    That mix is not specific to PSE, but is for a very large region. Seattle City Light claims minuscule coal, but a Seattle zip code produces the exact same mix on this site's report. So do central Idaho and western Montana.
  20. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    So unless you live in a region that gets all it's electricity from Hydro and renewables, don't get a plugin? And Hybrids still pollute, so I guess I'll just go back to driving a hemi pickup!:rolleyes:
