Consumption Screen Problem
Discussion in 'Gen 2 Prius Main Forum' started by taco1231, Sep 17, 2008.
  1. taco1231
    taco1231 Junior Member
    Hey All,
    I'm getting some really weird readings on my consumption screen. The yellow bars don't appear and I just see the battery recharge logos. Has anyone ever encountered this before? I'm planning on taking my car in (its only 1.5 months old). Its happened to me on 3 separate occasions. I've attached some bad cell phone photos (i think). Please let me know if you've had this happen.
    Thanks.
  2. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    This will happen when the vehicle has been stopped for more than 5 minutes. The mpg doesn't have a reading in those 5 minutes, so you will have a blank bar. Nothing to worry about.
  3. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    It is a feature, not a bug :) , on the 2006 and later Prius.
    We see 100 mpg bar during 5 min stealth driving on the 2004-2005 Prius.
    Ken@Japan
  4. Flying White Dutchman
    4,374
    313
    i get this in mu 2005 model prius to!? only then in l/km
  5. Fraser
    Fraser New Member
    667
    Navarre, Florida
    We've had a single blank five-minute position on a few occasions, but never three; but we haven't needed to stand still for that long. We've also had a 30-minute span of full bars at 99.9, but that was basically coasting downhill in Colorado. I don't see any reason to take the car to a shop.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's completely normal, just as the previous posters have stated.
    Tom
  7. taco1231
    Thanks for all the responses. I should clarify that I was not at a stand still for 5 minutes when these pictures were taken. I was actually on the freeway in bumper to bumper traffic moving at 10mph. Is that still normal?
  8. Patrick Wong
    18,200
    6,474
    If you don't have any warning lights on, don't worry. 52 mpg indicated on your MFD is further evidence that all is well. Also note that many dealers' service depts will charge you for an hour of labor in the event that no problem is found (to discourage no-trouble-found complaints).
  9. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Thats the most common place people see it. The car used only electric to inch ahead, and never started the ICE during that 5 minute period. The computer gets confused by moving some distance but using 0 fuel. Whatever the calculation is its making internally this ends up as 0 mpg instead of infinite mpg. One guess people have made is that its natively calculating L/km, and then converting. 1/(0L/X km) = divide by 0 error.
    Nothing to worry about, and does not appear to affect the accuracy of the MFD average MPG number. Its believed that uses the total distance and total gallons, and doesn't care about the 5 minute display.
    Rob
  10. ddan
    ddan New Member
    Bryn Mawr
    Had a similar problem today. It occurred while traveling (all EV during this 5 minute stretch... mostly downhill) on expressway while doing 15-20 mph. It was 15 minutes into my commute. Have driven under similar conditions and speed many times in same part of highway without this finding. Interesting quirk. We'll see if it becomes more of an issue.
      File size:
      106.3 KB
      467
  11. PaulHS
    PaulHS Member
    200
    SE PA
    I've had a similar pattern on the consumption screen as well. I was crawling along at about 4mph on a clogged 35mph street with slight ups and downs but generally up. I actually did a double-take when I noticed two consecutive blank columns; the first had two regen leaves and the second had one leaf. I'm still trying to figure out how I got so much regen with so little movement.
