Consumption Screen
Discussion in 'Gen 2 Prius Audio and Electronics' started by glscheil1, Jul 17, 2004.
  1. glscheil1
    glscheil1 New Member
    150
    Raytown, MO.
    I usually drive with the 'Consumption Screen' and when I first use the car, each day, the outside temperature is in centigrade. Later in the day, it shows farenheit. Is it possible to eleminate the centigrade and only show farenheit. When I'm in the car, I always forget how to convert to farenheit.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Weird, mine never shows centigrade. Have you checked to make sure you don't somehow have the AC temp display set to centigrade and the OAT set to farenheit? That's about the only thing that I can think of.
    Let us know what you find.
  3. petteri
    petteri New Member
    203
    Plantation, FL USA
    How do you set the AC temp to centigrade? I thought that only the speedo could be changed to mertic. Oh, the nav system will go metric if you select French as the language.
    Peter
    Miami, FL USA
