Just wondering if anyone has tried this tire on the stock rims in the 195/60/15 size? This tire rates #6 on the Tire Rack survey and is about $70. Also has a max tire pressure of 51psi and has rim protection sidewalls with low rolling resistance of.083. Thinking about putting these on Enkei J10 15x6.5 wheels that weigh only about 16 lbs each. This would give a tire and wheel weight of 36 lbs which is only 4lbs more than stock per wheel/tire. If anyone has this wheel or tire please let me know what you think? If not let me know what you think? Cosmicprius
