Convert to 5 seater!
Discussion in 'Prime Accessories and Modifications' started by KevinNg131, Jun 18, 2020.
  1. KevinNg131
    KevinNg131 New Member
    San Diego
    Has anyone try to convert you 2017 Toyota Prius Prime to a 5 seater? I am wondering if I can buy the 2020 Toyota Prius Prime back row seat to replace for the 2017 Toyota Prius Prime back row seat? Just curious if anyone has tried this modification ?
    I attached the picture of the frame under the seat. I am doing a HVAC fan service, so I am wondering if I can buy the 2020 Prius prime seaters and convert it to the 5 seater and mount the seatbelt?
    TGrracie, Rob43 and bisco like this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,594
    1,612
    Somewhere in Wisconsin
    2013 Chevy Volt
    I rather see someone convert it back to the solar option that belongs there
    Diemaster, m8547 and Nomina like this.
  3. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    Don't know if anyone tired it. But if even it's possible, how much the parts cost, unless you can find a cheap used parts from a junk yard from wrecked 2020 PRIME.
    Here is the list of rear seat components part. Which parts you would need to convert to a 5 seater, I am not sure.
    Genuine OEM Rear Seat Components Parts for 2020 Toyota Prius Prime LE - Olathe Toyota Parts Center
    Instead, I just traded my 2017 PRIME Premium to purchase a new 2020 PRIME LE. With incentives and rebate, it basically did not cost me anything.
    49,488
    i say go for it! what have you got to lose?(y)
  5. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    A bunch of money and possibly the ability to easily sell the car later.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Modding cars is fun (usually), if you have the time and the means I'd say go for it since it sounds like you want to.
    IMO, your worse case scenario is that you get stuck with the cost of a used junkyard 2020 rear seat. (Re-selling odd items like this will take time)
    Once you have a 2020 rear seat in your possession, you will lay it in to position to check for clearance. "If" you can make it fit, then and only then you'll modify the chassis for things like a new seat belt.
    If you can't make it fit, you've modified nothing and now you'll just reassemble your Prime back to the way it was.
    Rob43
  7. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Where's the battery hump that we were told would be under the rear seat ???
    Rob43
  8. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    They only removed the middle seat because they were too lazy to recertify the chassis for the additional weight of 5 passengers plus the battery.
    Did they make any suspension or tire changes in 2020 to increase the weight capacity? Does it still have the reduced capacity sticker on the door jamb?
  9. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    GVWR is an interesting thing...
    While it's "possible" for someone to completely max out the GVWR of their Prime and drive around that way, I'd make the argument that the vast majority of Prime owners are trying hard to get good MPG's; so they won't.
    Rob43
    #9 Rob43, Jun 18, 2020
    Diemaster likes this.
  10. ETC(SS)
    6,555
    Note to self:
    NEVER buy a used car.......
    TGrracie and Rob43 like this.
  11. KevinNg131
    San Diego
    The battery is in the trunk. They lied. I found the battery in the trunk. So I wonder how come they didn’t build a third row seat in the back? Do you think the other Prius lift back model back row seat will fit this 2017 prime?
  12. KevinNg131
    San Diego
    What do you mean it didn’t cost you anything? You trade in, isn’t you have to pay extra since most dealers buy back price is very low?
  13. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    The only way to find out is to buy one and try your install, it either will or will not fit. If you score big and it fits with no modifications, then you move on to things like seat belts.
    Good, luck,
    Rob43
  14. Salamander_King
    10,975
    8,867
    New England
    In NE with huge rebates and discounts plus state and fed incentives, I ended up paying ~$1000 out of my pocket (after tax credit next year) to exchange my 2017 Prime Premium with 40K miles with a brand new 2020 Prime LE. However, having a new car with 2 years of free Toyota Care maintenance and brand new tires on it, I saved on ongoing maintenance cost for the next 2 years and the price of set of tires I was due to buy on 2017 had I kept the car. That wiped ~$1000 I had to pay out of my pocket, so it was basically a no money exchange to gain the fifth seat for me. Of course, this dose not apply to everyone. YMMV.
    #14 Salamander_King, Jun 19, 2020
    MTN likes this.
  15. bisco
    49,488
    the four seat model was always about japan only solar roof with separate battery and control unit.
    suspension changes for us to get 5 seats may have played into it, idk.
  16. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    What suspension changes ?
    Do you have a link ?
    Rob43
  17. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    In the 2018 owners manual, the vehicle weight capacity is 670 lbs. The specified tire size is P195/65R15 89S.
    In the 2020 owners manual, the vehicle weight capacity is 840 pounds.
    The specified tire size is 195/65R15 91S (no "P")
    It looks like P-metric load index 89 at 35 PSI is good for 1279 pounds. The chart I'm looking at is blank for 36 PSI.
    ISO-metric load index 91 is good for 1312 pounds at 35 PSI or 1356 pounds at 36 PSI.
    So the load rating increased by 33 pounds per tire, but the weight capacity increased by 170 pounds total (42.5 pounds per tire). Maybe the only change is the tires, or maybe there is a chassis or suspension change too for 2020 to allow an extra passenger?
    Interestingly, the brake pedal clearance increased by 4mm from 2018 to 2020.
    TGrracie, MTN, bisco and 1 other person like this.
  18. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    ^ Good info...
    As you and many others know, I'm always in favor of Better tires than the OE Prime tires.
    Better tire's "usually" increase the 1279 lbs load rating.
    Rob43
  19. bisco
    49,488
    no link. i remember reading that a fifth person would require beefier suspension because they lightened it for the japanese version.
    then, when it wasn't selling well, toyota said they could probably add the seat without too much trouble, and they did.
    what they never addressed was the height of the battery pack.
    MTN likes this.
  20. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    For the reasons listed above, here is why I'm a Big fan of these tire sizes:
    1) Plus Two, 205/50-17 = 1433 lbs (Serv. Desc: 93V or 93W) 25.1 Overall Diameter
    2) Plus Zero, Yokohama AVID Ascend GT, 205/60-15 = 1356 lbs (Serv. Desc: 91H) 24.8 Overall Diameter
    3) Slightly taller for better ground clearance Plus Zero, Yokohama AVID Ascend GT or General AltiMAX RT43, 205/65-15 = 1400 to 1477 lbs (Serv. Desc: 92H or 94H) 25.5/6 Overall Diameter
    Rob43
