Cool JDM yellow wedge bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mediahound, Jan 21, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    tacopyro likes this.
  2. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    I have these installed, they're pretty good.
    And no modifications necessary. ;)
    SCH-I535
  3. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I did the same with amber bulbs. What a pita to change out though!
    PlusIV
  4. xliderider
    7,891
    3,125
    Honolulu, HI
    Can't complain about the Prius. I had to take the front bumper cover off, then pull out the headlight housing partially to even access the parking light bulbs on my Camry. :rolleyes:
    In the owner's manual it says to take it to the dealer for replacement. Yeah right...
    SCH-I535
  5. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Those were easy. It's the passenger low-beam that's annoying.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Cool to have as it's almost impossible to find matching bulbs for the LED headlights and they certainly look better than the ugly stack of yellow panels in LEDs.
  7. A.Reyes
    A.Reyes Active Member
    270
    178
    Beaufort, 29902
    What a clever idea. Maybe I'll switch to yellow. Never thought about that.
    iPhone ?
  8. mediahound
    903
    155
    These don't output quite as much light as a little LED bulb there does, they look better and more unique in my opinion
  9. D Unit
    D Unit Junior Member
    Bay Area, CA
    Do these twist out or just pull down out?
  10. mediahound
    903
    155
    They just pull out but the base attached to the wire twists into the headlight assembly.
  11. xliderider
    7,891
    3,125
    Honolulu, HI
    Quarter turn, counter clockwise to remove.
    On second thought, you want to remove the bulbs, and put the empty holders back in the housing. Or, you can disable the OEM parking light bulbs by cutting the two thin wires coming out of the bulbs.
    SCH-I535
  12. D Unit
    Bay Area, CA
    The quarter turn did the trick. I actually prefer the "parking light delete" mod... Thanks!
    Now I just learned that my driver's side amber corner light is out too. I prefer it unplugged (or out) but how the heck do you get to this one?!
  13. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    That's what I currently have ever since my set of parking light bulbs burnt out. Nothing there to mismatch with the LED headlights. However, I may go back to using yellow bulbs.
  14. mediahound
    903
    155
  15. mediahound
    903
    155
    I spoke to a Prius tech last week and he said it's basically impossible to replace that bulb without removing or at least pulling out the entire the headlight assembly... Every time he removes the headlight assembly for any reason, he replaces that bulb for free just because he's there and knows what a pain it is.
  16. D Unit
    Bay Area, CA
    He lied to you because shortly after I unplugged it, took out the bulb, then reinserted back into the socket.:D
  17. mediahound
    903
    155
    Maybe he has larger hands than you.
  18. D Unit
    Bay Area, CA
    Yikes! Don't tell my wife!
  19. xliderider
    7,891
    3,125
    Honolulu, HI
    Lol. :D
    SCH-I535
  20. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    He's full of shit. There are instructions in the Prius owner manual on how to change the front side marker lights in the do-it-yourself maintenance chapter.
    burstaneurysm likes this.
